Question about Motorola Lands Phones
Answermachine not picking up
MOTOROLA D210 I cannot get the answermachine to answer calls. I tried ringing my landline from my mobile, it just rings and rings. It only came on when I hung up the call on my mobile. It is switched on, the ring delay is set to two but it just keeps on ringing....any ideas?
I emailed Motorola support. Email bounced back and was redirected to their broadband support. Not what i needed at all. Tried again, same result. Gave up in the end and contacted BT who round a fault at the exchange which was blocking my Caller Id. Once they fixed this, the answer machine worked too. Weird. Especially as I plugged in an older phone earlier to test it and the answer machine on that one worked. Nil points to Motorola for support I have to say....
Posted on May 29, 2009
Would like to increase the number of rings before the answer machine starts.
Look again, gotta be threre - if still cannot find just enter "changing rings for ----" on google and see what pops up.
Aug 28, 2015 | Lands Phones
Why when hanging up the phone rings 4 times
Is the phone you are talking on a landline or the phone you are calling is a landline?
Mark
Motorola Support
Jul 07, 2014 | Motorola Cell Phones
INCREASE RING TONES FROM 3 RINGS TO 6 RINGS
Generally (without knowing what phone yopu have) you need to press menu, arrow up to answermachine or TAM then press OK then arrow up to settings or TAM settings then press ok then arrow down to answer delay/ring delay/ring number press ok then use arrow keys to adjust rings, when on required number, press ok.
Feb 25, 2011 | Cell Phones
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
I have a motorola V186 cell phone. When I dial a number, if no one answers after 7 rings, the phone automatically cuts out and says 'no answer', then I have to dial again. My mom is just about deaf and I...
You are lucky to get 7 rings out of any cell phone.
Cell carriers limit the rings permitted to keep the traffic down. If you call another cell, it goes to voice mail. A landline just stops ringing.
Jul 03, 2009 | Lands Phones
Phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Jun 02, 2009 | Lands Phones
BT Freestyle 2200 - my phone is linked to an answermachine at hom
It is possible that you accidentally turned off the ringer.
Here are the instructions for the ringer on the BT Freestyle 22000000000.jpg
Dec 17, 2008 | British Telecom Freestyle 2200 Trio...
Transferring calls-- transfers too quickly
You are transferring calls from your cell to your landline? Need more info.
Cynthia
Nov 04, 2007 | Motorola Mobility RAZR V3
Lands Phones Logo
169 people viewed this question
Top Motorola Lands Phones Experts
David Payne
David Payne
Are you a Motorola Lands Phone Expert? Answer questions, earn points and help others
