Question about Casio Watches
Took Casio G-Shock DW-6600 a little to far apart to swap the battery during a moment of mental weakness and can't get it back together and functioning.
SOURCE: manual
How do I replace the battery on a casio wrist watch?
Posted on Apr 28, 2008
SOURCE: I had my battery replaced
There are two internal springs that contact the back cover of the watch through an insulator. The alarm nor chime will work if they were not put into their proper locations or were omitted during reassembly.
Posted on Jul 01, 2008
SOURCE: i've changed my battery on my casio g-shock dw 003
Did the same with my DW-003 and thought I'd broken the Illuminator (and the alarm didn't work). Next battery change was via a shop and the illuminator worked again (as did the alarm). This was just a battery cahnge, rather than a repair job - One of those things, I guess
Posted on Nov 09, 2009
SOURCE: spring poppedout on dw 6900 g shock. need a
This happened to mine, couldn't get a spring anywhere. But managed to fix it by using a staple which I cut to size, Works fine now.
Posted on Nov 12, 2009
  • 2501 Answers
SOURCE: casio g shock dw-9052 how to change from military
You can get instructions from the Casio web site which will tell you how to set your watch..
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Feb 22, 2010
Dw-6600 need a manual for my watch, where to find one on-line
Hi.
Please click on the link below to open the manual for your Casio G-Shock (DW-6600 module 1199):
Casio owners manual.
Regards.
Ginko
Sep 08, 2011 | Casio Watches
Manual for Casio G Shock DW-6900
you can get
instructions from the Casio web site.
watches;
Accept terms
Sep 29, 2010 | Watches
Casio g shock dw-9052 how to change from military time to standard time
Accept terms
Feb 22, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Setb time for casio g-shock
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Dec 05, 2009 | Casio DW-5600E-1VCT Wrist Watch
I've changed my battery on my casio g-shock dw 003 but the illuminator no longer works! why?
Sep 30, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Model & spring issue with an ol casio G-Shock when replacing batt
This spring is connector to caseback for transmitting sound. Get an eyeglass and find out on movement backplate written SPRING COIL and put it back. If there is no marking SPRING COIL then check for the hole with approx. same diameter as spring (must easy fit in). The hole shoud be empty with contact spot at the bottom. Put the spring in and close the caseback. Check alarm sound. If it works, you did find the right hole- if not, try again till you find the right one.
Good luck
Arthur
Dec 13, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Loose spring popped out from behind....now I have no sound!
this video will show you were the spring goes next to battery
Jun 14, 2017 | Casio G-shock G2300B-1V
Manual for casio G.shock DW-5900
Apr 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
I had my battery replaced in my Casio G Shock DW -6800. Since then the beeps and alarms are not working. Is there some sort of reset button he forgot to press?
Apr 24, 2008 | Watches
Watches Logo
307 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
