Question about Kenwood VR-6070 Receiver
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Hi FixYa experts,
Just an FYI: I am a software engineer with some electronics background and an amateur radio license. I can read schematics and know Ohm's Law, and some of the other basics of electronics, and can test things with a multimeter, if you can respond.
I recently purchased a Kenwood VR-6070 receiver used. It has a problem, namely the volume knob (and its attendent buttons beneath, Mute and AV Aux) do not work; I think because at one point in the receivers life someone stood the receiver up with the front-face plate pointing down, which put 40lbs of pressure directly on the volume knob! The remote is broken too (I think, I tried two sets of fresh batteries and nothing happened; haven't checked to see if the IR LED blinks in a camcorder yet, will do that next), so I cannot adjust the volume level! Otherwise, the receiver seems to work fine.
Since the receiver seems to fine otherwise, here's my questions:
1) I suspect that the "volume control assembly" internal to the unit is broken, since the buttons beneath the volume knob are broken too. I'd like to know: What else is attached to the "volume control assembly"?
2) If I went out and picked up a new remote that could send out the IR signals that this receiver needed (say a universal Logitech Harmony remote), would it work? I ask this b/c an electrical technician friend of mine suspected that the receiver's IR sensor is on the same "volume control assembly".
I guess I'm kinda hoping for someone who has access to the service manual to help me to know whether I'd have to replace the "volume control assembly" or whether I can get by with just a remote.
Thanks,
Sheep
  • sheepsim May 29, 2009
    Sheep responding to my own question,
    Turns out #2 works, I got a universal remote and it can control the volume.
    Maybe this info would help others with similar problems.
    -Sheep
  • 55 Answers
Looks like you have several faults?
First try to fix the remote:
http://www.instructables.com/id/Repair-your-remote-controls/
Posted on Jul 11, 2009
I have a kenwood Auto video surround receiver DR / 409 how to reset it
PDF]KRF-V8030D VR-409 - Kenwood
manual.kenwood.com/files/B60-4593-00.pdf
VR-409. INSTRUCTION MANUAL. KENWOOD CORPORATION. B60-4593-00 (EN) ...on the country and sales area. AUDIO VIDEO SURROUND RECEIVER ...
Kenwood VR-409 Manuals
www.manualslib.com > Brands > Kenwood Manuals > Stereo Receiver
View online or download Kenwood VR-409 Instruction Manual. ... Kenwood Instruction Manual Audio Video Surround Receiver KRF-V8030D VR-409.
Kenwood VR-409 Receiver Repair Questions, Solutions ...
www.fixya.com > Forum > Audio & Video Receivers > Kenwood
Recent Kenwood VR-409 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
Kenwood VR-409 PDF Owner's Manual Download & Preview
www.manualguru.com > Kenwood Manuals > VR-409
Feb 03, 2016 | Kenwood Audio Players & Recorders
When I turn volume knob to a higher volume, volume decreases...
Could be a Japanese system, that's the way it works, unless u going to switch the outer wires on the volume controls, then it would work clockwise, that if its not soldered on the circuit board.
Oct 25, 2013 | Kenwood VR-505 Receiver
Need to find a remote to run the kenwood vr-510 receiver
The Logitech Harmony 700 (IR) works great for my Kenwood VR-510 plus my other video components. Got from E-Bay for $144 with 3 yr warranty, around June 2013.
Oct 13, 2011 | Kenwood VR-510 Receiver
Hi, I have a problem with my kenwood vr-205 receiver. My problem is that, my original remote that came with the system doesn't work at all. I put brand new batteries to see if it was the problem, but it...
test the remote by using the camera in your cell phone...you should see the IR lights flashing when you operate the remote...these kenwood receivers are notorious for having cold solder joints on the IR receiver...resolder joints like this http://mysite.verizon.net/amp68/ or http://home.comcast.net/~jcoxdesigns/Kenwood/index.html
Mar 18, 2011 | Kenwood VR-205 Receiver
Problem for Kenwood VR-405. Subwoofer has no sound coming from it. Sub is set to "on" in the menu and all speakers work in test mode. I have tried hooking devices individually with RCA's and also just...
How I fixed this was to get a can of electrical contact cleaner. Any auto parts store or electronics store will carry it. Take the cover off and remove the volume knob. It's responsible for the output volume to the sub. Pry the four silver tabs open and pull apart the knob. You should see some corrosion on the contacts. Use a fingernail file to clean them off now clean it with the contact cleaner. Put it back together and you are ready to go.
May 31, 2010 | Kenwood VR-405 Receiver
Kenwood VR-409 surround system clicks off when sound is turned up
Assuming you aren't turning the volume knob past half way before the problem occurs, you most likely have a damaged speaker cable or a bad driver in one of your loudspeakers. (Once your volume knob has reached about half way the amplifier is producing its maximum efficiency.)
Note the position of your volume control when the clipping occurs, then remove one speaker at a time and raise the volume. If you identify a speaker as the culprit, inspect or replace the wire running to it and try it again. If you aren't able to find a bad speaker, the problem is internal and will need to be fixed at a repair shop.
Good Luck,
BB
Apr 30, 2009 | Kenwood VR-409 Receiver
IR receiver on unit not working?
Sounds to me like the issue is the rx in the unit. It can be fixed with very little work if you can locate the part. Let me take a look and see if I can locate the part number for you. Although I have to say that Kenwwod can keep a tight lip on their parts lists.
Nov 22, 2007 | Kenwood VR-309
It seems to be a general problem on Kenwood Receivers. Pls check this out http://www.moerk.org/kenwood/ or this http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/
regards sgershoj
Nov 06, 2007 | Kenwood VR-505 Receiver
IR Reliability--Intermittent
The Kenwood VR-510 does indeed respond to IR remotes. I now use a Logitech Harmony H659 which is IR only.
Your issue is a problem with the VR-510, actualy the whole series had a problem with cold solder joints on an assembly behind the front panel. Fix that and fix the problem. It frustrated me for 5 yrs.
Go here for the fix:
This site has the fix well documented: http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/.
All is working great now!
Jun 08, 2007 | Kenwood VR-510 Receiver
Kenwood VR-6070 Receiver Logo
673 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
