Question about Acer Aspire One AOA150-1784 Netbook
Whenever I insert a new wireless mouse or any thumb drive into a USB port my Aspire asks for a driver. Previously the drivers for these devices installed automatically.
  • robot601 May 28, 2009
    Thank you. That seems to have fixed it.
    Problem Solver:
  • 7 Answers
You probably turned it off by accident. Go to Start > Control Panel > System > Hardware and choose "Windows Update" under "Drivers". Make sure either the first or second choice is selected.
Posted on May 28, 2009
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Installing wireless mouse on Windows 7 Laptop
connect to the internet with your laptop and then plug in your mouse,windows 7 will automatically find the driver for you :)
Mar 07, 2011 | Computers & Internet
Just installed MS 3000 wireless mouse. Won't run. no light on mouse. Have put new battery in and still no light. Flash drive has light. What to do now? Yes, I pushed the connection pins on both.
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
don
Feb 24, 2011 | Microsoft Wireless Notebook Optical Mouse...
Neither the Acer supplied wireless mouse or wireless keyboard work with my new Acer Aspire M3300 PC. I inserted the supplied batteries the correct way round and the blue led come on for a few seconds,...
make sure you have the right keyboard and mouse selected
this will depend on which operating system you have
click start control panel view devices and printers you should see your mouse and keyboard right click on either select properties then hardware make sure you have the correct one selected in W 7
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
this will apply to keyboard to in XP
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port ((if applicable))
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
hope this helps you
Aug 30, 2010 | Computers & Internet
Hi does the acer aspire 3684wxmi\r\nhave an on off
remove the mouse...and insert it again ...after restarting the computer ..Being a usb mouse this is just a matter of driver ..so probably needs reinstalling ..if you have the original driver just insert the disk and run it ...and restart ..if not ..go to control panel and run the add new hardware wizard ...choose already added ..and it will search for devices..if it does not find it ..change the usb port ..and try again ...if you know that you had the driver in it ...and you didnt reinstalled teh computer ..it will find it and ask for driver or start the wizard ...in this moment just run it automatically ..
Jun 15, 2010 | Acer Aspire One PC Notebook
Want to use wireless mouse with my laptop how can I do this. I have a window vista laptop
Just buy a USB wireless mouse. There is a transceiver that plugs into the USB port of the computer, the size of a thumb drive, and it sends and receives signals to the wireless mouse. In my opinion, a wireless, optical mouse is the best. Normally the footprint (size) of the mouse is smaller than a desktop one as well if you choose. With Vista, just plug it in the USB port and windows should install the drivers without any disks. But if it doesn't just insert the disk that comes with the mouse. You only need a driver for it. A driver is a set of instructions that tell the device what to do. Every piece of hardware in your computer has a specific driver.
I hope this helps and good luck.
Oct 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Missing thumb drive for mouse. can i load drivers on a regular thumb drive?
Sorry, but no. The USB device is not a thumb drive, it is a transceiver that "talks" to the mouse and picks up the movements and inputs them to the computer. Without the USB device, you have a paperweight. These are selling for less than $20, so just replace it.
May 10, 2009 | Computers & Internet
USB wireless keyboard doesn't work
You need to unload the USB drivers for the keyboard and let windows find them again at restart. How does a novice do this? It's not hard. Go to Start, Control Panel, System, Hardware, Device Manager, Keyboards. Right click on this and select uninstall. Reboot your machine. If the drivers are not corrupted they should load fine, if they are corrupted then Windows will ask for the original operating system disk.
All this assumes that your keyboards are electronically working. This last holiday season alot of people brought in their Logitech - Target specials that no longer worked. Seems that if you insert the batteries backwards once the keyboard no longer operates (mouse OK). Never checked in to it too deep.
Good Luck
Mar 19, 2009 | Acer Aspire 5100 Notebook
USB Ports Stopped Working
Well let me be the first to say I see you have skills. All of your troubleshooting is exactly by the book. The only thing I see that was not checked is the CMOS (BIOS) setup screen to make sure that the USB function is enabled there. Good luck and let me know how it goes, we have a couple of hundred years of experience at FixYa so keep me updated if you have any more problems.
Jan 05, 2009 | Acer TravelMate 2300 Notebook
Aspire 3610 USB ports
I think you might have a loose cononection for the data ports. Try putting a little bit of force on the usb device. Up, down left right. NOT ALOT. If it starts working when force is used, i tihnk you should try to take it apart and resolder the connections. If it dosen't work, uninstalling the driver and installing.
Jun 01, 2008 | Acer Aspire 3680 Laptop
Acer Aspire One AOA150-1784 Netbook Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
