Question about E-Machines eMachines Desktop PC
Drives won't read disc
F drive & e.drive will not read disc
    Genius:
  • 1,601 Answers
Why won't my packard bell's cd disc or floppy disc drive won't open
CD / DVD and most optical drives - Manual eject by sticking a straightened paperclip in the tiny hole and gently push open.
Apr 02, 2013 | Packard Bell Computers & Internet
Won't read the floppy Discs
follow these solutions in the steps I list
1. Reinstall drivers
2. Unplug the floppy drive from the mother board and plug it back in, reboot
3. Try another floppy drive.
4. If all else fails, it may be an issue with the OS.
Sep 20, 2012 | Mitsumi (FA404MBLACK) (fa404m/black)...
My Toshiba Model L505-S5993 laptop won't read
Hello there,
The problem is that the Drives lens is already bad and cannot read any disc, no matter the type of disc you put into it, it wont read it still. The solution is to replace the drive. Replacing it is the best way to solve the problem. If not trying to replace the lens is going to be futile as the lens for the driver is not available and when you install a new disc drive, it will have to install the drivers software.
If you replace the lens, the laptop wont be able to install the drivers of the lens as it reads it alongside the driver itself and if they are not compatible, it wont install the drivers software. So my best advice is for you to replace the CD drive.
My laptop is a typical example because my disc drive is also bad. And i had to replace the drive and not the lens.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | Toshiba Satellite L500 Series Notebook
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
Dvd drive cant read dvds but can read vcds
First of all, are you trying to read Blu-Ray DVDs? Unless your drive is made for them, it won't be able to. The same may be true if you're trying to read a dual-layer DVD. Not all DVD drives can handle them.
CDs and DVDs need different kinds of laser light to be read, and a combo drive like yours is essentially two drives in one. Sometimes a problem develops in the pickup and it can read one kind of disc and not the other. My experience is that it's usually the DVD function that fails more often. The data on a DVD is much more densely packed and harder to read.
Try making sure the discs you're trying to read are clean. If the problem is affecting all the DVDs you try, replace the drive. New drives for a desktop computer only cost around $20 to $30 and they are easy to change. In a laptop, the drive will be more expensive and maybe hard to find; in that case you may want to consider a USB external burner as a replacement. This is also an option for desktops as well.
May 20, 2011 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
I have a issues with LITEON DVD-ROM LTD163 ATA DEVICE and i bought call of duty 4 modern warefare and I installed it and now it won't let me play single version at all since it don't show up in...
well if another Disc works (try a movie or something) it means that the disc itself is damaged. Now I'm betting that the other disc dont work eighter, This is because the rom has reached its life span. Replacing the rom is the solution to your problem.
May 07, 2011 | Lite On LTD 163 Internal DVD Drive
Wont read blank discs
Check the RW label, if it's ROM, it won't read them since it's only for lecture and not for writing
Apr 22, 2011 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
E-Machines eMachines Desktop PC Logo
14 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
