Home | Candy | CDV262 Dryer | Squeeking / squ...
Candy CDV262 Dryer
Problem for Candy CDV262 Dryer
Squeeking / squeeling from Candy cc2 17 smart dryer
By vcollis on May 28, 2009
I got an 18 month old drier and would like to know how to solve a squeeking / squeeling problem - it only does in one direction and it sounds quite loud - it has always been a 'noisy' drier form new - the belt is ok and tight - The filters are clean - the difficulty is getting to the motor and tensioner device - i've got some technical knowledge but cant see a way to get to them please help andy and di Loud squeaking/grinding noise stared in one direction only, but gradually built up to all the time! Seems OK when cool though, ie when first switched on and cooling down at the end of cycle. Drier still works very efficiently but this sound is driving me mad! Any suggestions??
Comments:
Jun 07, 2009
- Yes I rang for an engineer and he charged me £40 to oil the pulleys! Never mind, he showed me how to do it for next time, they are set into the dryer about 6 inches so a long screwdriver is needed to trickle oil onto the wheels. And no squeaking!!
Best Solution
posted on May 31, 2009
Helpful)
olddewsons
Rank: Wiz
Rating: 81%, 14 votes
hi,well if its not the belt,there should be two rollers in front of drum at bottom,they are wearing out or need oiled.as for getting to motor and belt,well not sure of model,but most of dryers,you will have to take front off of dryer,then remove belt the tumbler.you should be able to reach tension,and release it to get slack in belt. hope this helps. duane.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Candy CDV262 Dryer
Questions and Unsolved Problems for Candy CDV262 Dryer
Do you recommend Candy CDV262 Dryer?
Answer
Answer
How can i open a hoover vh381 condenser dryer
Answer
Start button? we have replaced the door hinge but still does not work. Start button does not click... (More)
Answer
the green disc inside my candy fridge has turned from green to black, what does this mean?
Answer
I got an 18 month old drier and would like to know how to solve a squeeking / squeeling problem - it... (More)
Answer
whilst changing the belt on our candy cdv262, some of the wiring connections got tugged lose and now... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Candy CDV262 Dryer:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14110
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
