Question about DISH Network 311 DTV Receiver
Digital picture often gets jumbled for 2-3 seconds
Often, when watching both live TV or recorded programs, the digital signal gets jumbled and distorted and 2-3 seconds. I can understand this in inclimate weather, but it often happens with clear skies, and on different channels, not just the same channel. What is this caused by?
  • 374 Answers
This is often due to a limited line of sight issue such as foilage growing into the signal pathway. Often it occurs when the wind blows and the foilage sways into the signal path. From behind the dish look out at the angle of elevation the dish is pointed and try to identify if there are any obstructions in the area. If you are unable to determine this yourself call for a service call and they will assist you with obtaining a better line of sight. I hope that is helpful. Thanks for using Fix Ya.
Posted on Aug 15, 2009
Panasonic troubleshooting
I guess you mean a Set Top Box to convert digital TV transmission to old analog TV. Choose the correct video format for your screen.
Ah... Perhaps Your recording at an old standard & passing it to a modern TV or HD TV with the digital output from 1080 HD to 720 or lower still.
OR
Get a Digital Hard Drive recorder.....
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
Main Features:
DVB-T Twin Digital Turners
DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
2.5" Sata Hard disk: 500GB
Time Shift Function (Pause live TV)
HDMI Digital Output
Digital Audio Output
CVBS/YPbPr/SPDIF connectors
Supports TV formats 4:3 and 16:9
Electronic Program Guide (EPG) up to 7 days in advance
EPG searching and auto download
Recorded program edit
Parental Control
Copy files from internal HDD to external HDD
Built-in WiFi
Network Playback
USB 2.0 Interface
Aug 14, 2014 | Panasonic Televison & Video
Not receiving a TV signal through the DVD recorder and cannot record programs or watch TV through the DVD recorder
Firstly you must have a good connection from your antennae to the dvd recorder, secondly a good connection between recorder and tv
via scart lead or hdmi. Check these out before you do anything else.
Mar 21, 2014 | Panasonic Dmr-XW380 Dvd Recorder
Digital convertor
Do you mean the Samsung DVD-VR500E? The following steps should work for most DVD recorders. (In the US, you use the AV Input with an RCA composite cable or the RF input.)
If you get a digital-to-analog converter (set top box) and your current antenna provides the OTA signal at your location, then yes you will be able to record a digital program. Connect the set top box to AV1 or AV2 (the SCART inputs). Then use the Input Sel (under PR mode) to select the input. (Alternatively, connect an RF modulator to get the signal to the coax input from the STB to the recorder.) See page 75 of the manual for the DVD-500E for details on setting the input for recording: http://downloadcenter.samsung.com/content/UM/200410/20041023105238671_00500A-VR300E-XEU-E-B.pdf . Some DVD recorders only record on the TV (coax) input. In that case, you will need a set-top box with a RF out or an RF modulator but you can still record the digital program.
A dual tuner set top box will let you watch one program and record another if both the TV and the recorder are connected to the STB. If your TV has a digital tuner, you can split the incoming antenna signal to go to the set-top box and the TV. (Then you can also watch one program and record another.)
I prefer to use a switch instead of a splitter to reduce the signal loss. However, this forces me to record the program that I am currently watching. Since most of my recording is for time-shifting, this doesn't cause me a problem.
This site, http://www.ricability-digitaltv.org.uk/pages/products/stbs/stb_search_results.asp , has a list of reviews of set-top boxes for the UK. I know in the US, it is harder to find new converter boxes. However, they frequently show up in the used market as people replace their older TVs. This may apply in your region as well.
I hope this helps.
Jun 01, 2012 | Televison & Video
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
My VCR not recording after the switch to digital tv signal
The answer to this question can get a little complicated. Lets tackle it in two parts. First the last part; the part about picking up channels as decimals. With analog TV transmission, it took the full television broadcast channel to transmit one standard definition TV program. The newer digital transmission system uses some advanced video compression and audio compression technology to reduce the data needed to transmit the pictures and sound which allows the same bandwidth to deliver either High Definition Television programming or MULTIPLE channels of Standard Definition programs. So in your example above, you use to watch one channel of programming on TV channel 4, but now the TV station can broadcast multiple channels of programming on channel 4, sot they delineate the programs with a decimal point. So 4.1 it the first program on TV channel 4, 4.2 it the second program on TV channel 4..... Well, I hope you get the idea.
Now for the hard part of your question. I believe that before the transition, even with your new digital TV, you were still enjoying the analog broadcasts from your stations. Your VCR picked them up and recorded them and your digital TV could tune them in and you watched as you had always done in the past. After the transition you noticed that your VCR could not record anymore and your digital TV had discovered the digital channels that replace the analog channels. To remedy this situation, your VCR will need the aid of a DTV converter box to tune channels, and you may have to reconfigure the way your TV and VCR are connected. The best resource that I can give your for the reconnecting is the website http://www.fcc.gov/cgb/consumerfacts/converterbox_vcr.html. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Scroll down to the Normal 0 false false false MicrosoftInternetExplorer4 section about “Set-up #2: Watch One Channel while Recording a Different Channel”.
Hope this helps
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
Sony 52" Bravia LCD will drop picture and sound for 1-2 seconds
the only thing that i can think of is that the cables and connections are bad but if that is not the case it may be the internal components of the tv. my guess is that the tv was dropped or jumbled around while transported and what happened was internal components were broken or just mixed up so go to the retailer and get a refund or a new tv. hope this helps
May 22, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
Can I watch tv on 1 channel while recording another?
Unfortunately no, unless you get a second converter box. You're using the converter box to select channels, and it can only be on one channel at a time. With a second converter box, you might find you need a second antenna too (so you can get a signal on both channels). And you can't program your VCR to record on different channels (since it can't control the coverter box to change channels).
(This is a case of history repeating itself. When cable TV was new, and most TV's and VCR's weren't cable-ready, you needed to use the cable company's converter box. The same problems came up then too!)
Nov 30, 2008 | Insignia Digital-to-Analog Converter for...
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
DISH Network 311 DTV Receiver Logo
126 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
