Question about HP Pavilion dv6000z Notebook
Laptop shutting down by itself
I have a HP Pavilion dv5000 and it has recently started shutting down by itself. It just shuts off instantly. Sometimes it also freezes so i have to restart it. Is this a hardware problem or could it be a virus/software issue?
thank you
  • 2 more comments
  • nmjvans May 28, 2009
    it shuts down...without any "windows is shutting down" notice window. other times it freezes and then i have to restart
    i did think the first couple times it happened that its a over heating problem because the laptop was realy hot in the corner where the fan is,but other times the laptop isnt hot at all,might still be it though so will look into it thank you.
    No i am not aware of any sensor and i also havent let me laptop fall causing any possible damage. the problem has only ever happened while the laptop was stationary
    thanx leecom72, i think that could be the problem as i work in a dusty environment and also use the laptop in bed at night. i think i will take it to a service centre for a proper cleaning or do as u instructed. thank you all
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    HI there.
    Does the laptop shut down or does it restart?
  • HP Master
  • 4,806 Answers
Hi.
It sounds to me like the machine is overheating, and is mainly because of dust.
The best way to deal with this is to buy a can of compressed air and give short blast through the air vents and the CPU fan (located under the laptop), once the dust has been cleared out it should stay on for much longer.
Another bit of advice is not to use the laptop in bed, if you are make sure there is a flow of air passing through and that its not sat on any quilt covers.
Good luck and thanks for choosing FixYa!!
Posted on May 28, 2009
  • 489 Answers
It looks like over heating issue. get to service to check cooling system.
thank you choosing FixYa
I had the same problem but it turned out to be a simple one. First of all have you ever replaced your battery? If the battery is going bad it will shut off of course. But if the battery is bad and you use the power adapter it will also shut off. Remove the battery and use the power adapter only and it should stay on. The power adapter charges the battery under internal power management but if the battery is no good it can not complete the circuit. By removing the battery you bypass the recharge circuit in exchange for direct power.
Posted on May 30, 2009
    Problem Solver:
  • 7 Answers
Does it have a sensor to protect the hard drive if it falls? This could cause it to lock up or shut down as you describe. It could also be a loose battery...
Does the problem occur when you are moving it, or also when it is sitting still?
Hp laptop pavilion shuts off by itself
its either a bad power chord or the power supply or fan
Jan 05, 2013 | HP Computers & Internet
My laptop (HP Pavilion DV5000) shuts down in the process of reformatting.
Go into Control Panel and change the power settings so it never hibernates or dims screen.
Jan 04, 2010 | HP Computers & Internet
Battery with HP Pavillion DV5000 won't work. Do I need to replace the battery or is there a battery charger I could use to recharge the battery? Dianne
You can order a power cable online or pick one up at your local computer store. They should run between $80-150. The battery itself is very expensive to purchase but is rechargeable.
Oct 22, 2009 | HP Pavilion DV4015cl Notebook
Standy By Going off/Computer shutting down
The presentation power scheme is used when you are giving a briefing using the PC as your slide show. So the presentation power scheme will never shut off the monitor or the hard drive, don't want it to shut down in the middle of a briefing.However, leaving it in that state for long periods of time may cause the CPU to overheat and shut itself down for protection. A better scheme for quick boot up would be Home/Office. Turn monitor off after 20 minutes and "never" for hard disk. This way it will save energy (therefore heat) and you will have a quick boot up. If you are using XP Pro, there is also an option to automatically put it in standby when you close the lid of your monitor. Hope this helps. If you have any questions let me know... Please rate this solution before logging off.
Feb 04, 2009 | HP Computers & Internet
How to have access to the processor fan for hp pavilion dv5000
I found the Service Manual of the Notebook which contains the procedure about how to remove each and every component of your Notebook and below is the link to access the same :
http://h10032.www1.hp.com/ctg/Manual/c00700932.pdf
Best way is to copy the entire link and paste it in the address bar of a new web browser and press enter to open the link.
Hope this is helpful...
Oct 06, 2008 | Computers & Internet
Hp webcam
I had this problem myself. After a LONG talk with an HP technician we finally sorted it out.
It was actually down to several programs trying to use the camera at the same time, mainly instant messengers, so the first thing to do is to shut down all instant messengers. If possible, from their preferences stop them running when the machine starts.
Once you've done that, try the HP Quickplay (any of the little buttons) and go to the camera from there. It should work. Sometimes a reboot is required if a particularly obstinate instant messenger has activated the camera but not turned it on, and won't release it.
May 25, 2008 | HP Pavilion dv6000z Notebook
Shutting off
i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
Apr 22, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv6000z Notebook Logo
341 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
