Question about Canon FS100 Flash Media Camcorder
Failure to initialize and use memory card SD/SDHC / canon fs100 camcorder
The camera fails to recognize the card and continues to flag error when the card is loaded and asked programed to format/initialise, it doesnt recognise the card, have tried new cards and have had no result. I have the exact same problem. Did anyone find a solution? I have the Canon camcorder FS100. I have problems getting it to use (read, write and initialize) SDHC memory cards. (Maybe because of the size 16GB and 32GB). Has anyone experienced the same problem, and more important, has a solution. (or maybe just an explanation, so I can search the solution elsewhere).
I had the same problem but fixed it by initializing the SDHC Card. It explains it in the manual. If you go to the menu and then down to the card it gives the option to initialize it. I did that for all my cards and now they work fine. Hope that helps...
Posted on Jun 11, 2009
  • 18 Answers
Have you tried resetting the camcorder to factory default and then using a new card try kingston 16gb sdhc class 4 no other fancy spces and see if that works and if it doesn't you need to either return to dealer of purchase or send to Canon
Posted on May 30, 2009
After inserting an approved memory card the following message shows up 'Memory card error' - what to do?
Try another new memory card, if it continues to give you an error go to the main menu and look for FORMAT, some times you need to format the card so the camera can recognize the new card.
May 24, 2014 | Canon PowerShot SX20 IS Digital Camera
When I put the sd card in and then turn power on it ask to format. no matter if I input yes or no the camera then shuts off
i have this w5 camera for the last 3 years few months back an error appear named E;91: like that and sometimes a beep sond for few seconds also on flash mode i cant take pictures i solved that problem by initialise the settings.now that problem started i initialise and formatted also remove the memory stick and again initialise and formatted but the error continues.i can only take pictures without flash what can i do please give me ur valuable suggestions
Oct 12, 2009 | DXG Technology DXG-572V Digital Camera
Have a Finepix S602Zoom which on warning display now shows ''Card not initialised''- have bought a new 4GB card- but still have the same problem.. Any ideas - software prob?
This is a common error in the FinePix product range. When you receive a "Card Error" or "Card Not Initialized" message, this indicates that your camera's memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most users will use the "delete all" feature and continue to take pictures but by doing this the file format of the card may become unstable and unusable.
Fuji recommends formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted the images will not be recoverable. So format the current cards and they should be useable again.
Sep 25, 2009 | Fuji FinePix S7000 Digital Camera
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Initialising 5Gb micro disk for Fujifilm M603
There is a limitation with this camera and the size of memory cards it can handle. Larger cards than 1GB, are not recognized properly. You can however use larger cards if you format the card in the camera using the USB cable connected to your PC. Just connect the camera to your PC. In windows explorer select the camera drive, right-click and select "format". I have used this to get a 2GB card working with my 603. Beware that files larger than 1GB can not be stored on the card. I once had been recording a video at concert for about 30 minutes with the 2GB card installed (the camera got really hot during this shooting!). When hitting the record button again to save this giant clip, I got an error message "write error" I was a sad puppy that night.
Feb 16, 2008 | Fuji FinePix M603 Digital Camera
"Card not initialized" message
Go into the "setup" menu on the camera, and select "format".lem This will reformat the card and should fix the problem. The manual actually reccomends doing this in addition to using the "delete when copied" function in the Finepix program
Feb 05, 2007 | Fuji FinePix S5200 / S5600 Digital Camera
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Canon FS100 Flash Media Camcorder Logo
2,767 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
