Question about GE 25932 Cordless Phone
Feature does not work
When I have an incoming call and press FLASH, nothing happens. Any ideas?
  • 77 Answers
The flash button will only work if you already have a call on the line and another incoming call is coming in.
Posted on May 30, 2009
Resetting Admin
Try using FEATURE **2223772 2223772#. This is the access server admin. There might be a path there to reset passwords. On the MICS side use FEATURE **266344 266344# to access the system programming and password reset features. The best place to get free help from telco professionals (especially Nortel) visit Telephone Tech Talk - http://sundance-communications.com/forum/
Dec 08, 2014 | Nortel Norstar T7316e Phone
How do I turn the ringer off at my phone for external incoming calls?
Go into the extension programming and change the line settings to no ring. It is best done if you have a display phone so you can see the changes. If not, then you will need to look at the flashing line lights when you enter the programming mode.
Press Feature 00. This will take you into the programming mode. You should see the line buttons lit up green. They will be Solid (Immediate Ring) or Slow Flash (Delayed Ring) or Fast Flash (No Ring). I assume yours is solid so push each line button until it changes to a fast flash. Once done press Feature 00 to exit the system and save the settings.
Sep 11, 2014 | Avaya Lands Phones
Incoming calls do not ring
Is the line ringing turned off? A quick check is to press Feature 00 from any extension and look at the line lights. If they flash fast then the ringing is turned off. To restore ringing press the line button until the light turns solid. Then press Feature 00 to save and exit.
Aug 26, 2014 | Avaya Partner 18 Eurostyle 18D telephone
I have a Lucent (Avaya) Partner 18 phone system. One extension will not ring when there is an incoming call. I have set the extension to immediate ring but it still does not work. Any other ideas to try?
see if the DND or do not disturb is on. It should be a lit button programmed on the set, if its not programmed press feature 00, press a blank button and press feature 01
Sep 11, 2009 | Lucent PARTNER18 Corded Phone
Security light will not work
You must have a three function wall switch. This means in addition to a button that opens and closes the door there are two other buttons on the same wall switch. One is marked LIGHT and the other is marked LOCK.
To have your lights come on automatically when you walk into an open garage you must START with the lights ON. To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Aug 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
I'm trying to reset my speed dial numbers. I'm
I can think of only two reasons it doesn't work. What "Code" are you dialing? If you can't dial 600-699, then you are not at extension 10 or 11. If you're trying 80-99 you don't press FEATURE again.
Carl
Feb 25, 2009 | AT&T Partner 18 Phone (315805B)
DO not disturb feature will not turn off
do not pick up the headset
push feature 69 feature
Jan 20, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Answering blackberry with Plantronics ATT V521
I pull the battery from my blackberry and I can use the voice dialing again.
Jun 20, 2008 | GPS
Problems with Intercom
Yes, you just need to program those buttons on your phone. Press "feature" then "redial" then press the button you want to program, then press "1" then it's extension # (example: 1-0-0 to program the button for extension 100) then press "feature". After you've programmed those extensions, the intercom should work.
Dec 20, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
GE 25932 Cordless Phone Logo
37 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
