Question about Konica Minolta Office Equipment & Supplies
Error code P27 - Konica Minolta Office Equipment & Supplies
  • tapiokaleva May 29, 2009
    konika 1212
  • rburlsull73 May 11, 2010
    What Model number.
  • 48 Answers
P27 is a TDS sensor error. You need to check the connectors on you developer unit. Open front cover, push down on copier then lift green handle. remove screw just above toner suppy unit and remove your drum assembly. Next remove your developer unit(two latches hold it in place). your TDS connector is located under your dv unit(you will have to remove the black cover). When finished reinstall drum assembly then turn on copier. If problems persist turn copier on while holding down 47 then press 40 then start.you should hear a motor running (let it run for 1 min.) If you don't try P40 or 01. Turn copier on then back on. If the problems persist I recommend a service tech. your DV or TDS sensor needs to be replaced.
Posted on May 30, 2009
On screen show E and can not print or .How to remove
Your calculator is beyond repair. You can use it in no print mode ohly. The printer is not working, causing the error code.
Turn it off and back on and only use the display mode.
Dec 15, 2015 | Canon P27-DH 12 Digit Mini Desktop...
C450 p27 bizhub
check the transfer roller the sponge looking roller on the right side of the machine when you open it
Jan 07, 2014 | Konica Minolta Office Equipment & Supplies
In my Konica 1216 photocopier machine there is an error p27. how to fix this it?
The Access to this page has been denied by your administrator
https://www.facebook.com/
Aug 17, 2013 | Computers & Internet
Error P 26
<Error Code>
P22, P26, P27, P28, P09, P06, P08
Request for a repair service
  • Request either Canon or the dealer you purchased the machine for a repair service.
from : http://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MG_series/PIXMA_MG2140.aspx?faqtcmuri=tcm:13-875871&page=1&type=faq
Jul 07, 2013 | Canon PIXMA Office Equipment & Supplies
Konica 1120 display p27
Developing unit problem, check the developer(black powder) if enough or sometimes is old full of paper dust. After replacement of developer perform calibration TDS . If p27 still appear replaced developing sensor( under it).
Feb 18, 2013 | Konica 1120
Error code P27
Description
P26 or P27 at power up or during copier operation.
Solution
PROBABLE CAUSES:
1. Open connection from the TDS sensor to the main CB or lack of developer. The TDS output is abnormal (0.2V DC or lower).
Verify that the sensor output is above 0.2V DC by monitoring CN6-A9 on the main CB while running the main motor in diagnostics (47 mode, output code 40).
Repair any poor connections to the TDS sensor and supply developer if necessary.
2. Code occurs after resetting the PM counter and P26 occurs if machine is powered OFF/ON, because the L-detect (TDS) adjustment was not performed
Jun 01, 2009 | Konica Minolta Office Equipment & Supplies
Error code p27
this is a toner density failure code if the service company replaced the developer and did not run the density adjustment it will through this code or it could be an older firmware version you need at least level 16 or it could be a bad toner sensor i would recomend having them come back out to fix it
Apr 05, 2009 | Konica Minolta Office Equipment & Supplies
P27 error keeps coming up on a Konica 1212
Run 47 mode output code 51 until the unit does not reoccour may take 5 to 10 attemp,
b. poor conection at cn95, reconnect cn95 located under the front of developer
Jan 02, 2009 | Office Equipment & Supplies
Error code 27
The error code p27 the toner density sensor unplugged/dirty/faulty
Any problems please get back to me
thank you
Feb 19, 2008 | Office Equipment & Supplies
241 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
