Question about Bosch 24 in. SHX33A05 Stainless Steel Built-in Dishwasher
Not draining; about an inch of graywater in bottom. Dishes not clean. Unit is about 5 years old.
Bosche 24" built-in dishwasher not draining.
  • 10,865 Answers
Hi there. let me help you. check these things below and get back if we did not isolate the problem for you.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on May 28, 2009
I have maytag dishwasher leaves food residue
there is a filter on the inside bottom of the dishwasher check and clean it
May 16, 2010 | Maytag 24 in. MDBH970AWS Built-in...
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
Top dishes don't come clean
Dear friend,
ngfam at you service! happy to assist!
Go into the user manual and read how to properly load your dishes to get the maximum cleaning potential!
there are certain ways to load the dishwasher that allows the spry to hit all the dishes.
Second check the bottom of the dishwasher if there are food particles left on the bottom at the end of the wash!
They can be the problem if they are recirculating back onto the dishes and then drying on them when the dry cycle goes on!
Third, They sell for about 5 to 8 dollars a small box of dishwasher
cleaner that you ad and run with no dishes in it 2 times a year!
And last, there may be a problem withe the drain or pump that its not pumping out all the wash water!
If this is the case you need service to check it out before some one in your family gets violently ill..!
We sell appliances for 65 years and I recommend this nation wide Factory repair service to all my retail customers!!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | GE 24 in. Profile PDW7800 Built-in...
Superba Kudso15l551
check the check valve it may have something in it.
Jun 10, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Not cleaning properly. Not Draining properly?
Don't Buy GE :)
pump may me clogged does it drain, can you hear water spray. is water filling into unit on start up? I had to take pump of bottom of mine had piece of tooth pick jammed in impeller + GE just stinks anyway. I will never buy again
Jul 04, 2007 | GE 24 in. GLD5860LSS Stainless Still...
Bosch 24 in. SHX33A05 Stainless Steel Built-in Dishwasher Logo
498 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
