Question about Jandy Laars Lite2 Ld 400,000 Btu Heater
Laars Lite 2 LD heater - shuts off after 5 seconds
This heater is old (8+ years?) and has been neglected by former owner. Heater shuts off after 5 seconds of running (even after backwash w/good flow). After it shuts off, white smoke billows out of the top of the heater. I've let it sit for 5 minutes (following instructions on the door panel) and tried again, but the second attempt resulted in a rather violent ingition (loud noise and more white smoke).
  • bbailey681 May 28, 2009
    Sandy - Thank you. I don't see a coil on the parts list. Does it have another name or better yet, do you know the part number?
    Sergeant:
    Champion:
  • 219 Answers
Hi dear,
well the problem is in the coil of ur heater. As u said it is quite an old heater(8+ years) and the coil usually get damaged in 5-6 years. Well u have two options either u get ur coil repaired or get it replaced but i would advice u to get it replaced as it is quite old one.
Thanks!
Sandy
Posted on May 28, 2009
  • Sandeep Gupta May 28, 2009
    hi,
    well it is the wiring in ur heater.You should take it to some mechanic and he will repair the wiring as u would not be able to perform it.
    Thanks!
    Sandy
I have a laars lite 2 manual controls natural gas. The unit starts up runs strong for 5 mins shuts down restarts runs for now only seconds and shuts off
sounds like the hi limit switch is shutting it down,because it is not getting enough water,cloged filter, valve to heater notopen,bypass valve not closed,open up the water releif valve with the pump running should be alot of water running coming out of it.
Jun 13, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
We have a laars lite 2, when we openned the pool
Thank you for posting your question here on Fixya.com.
It could be...does it open up at the point the heater shuts down? Check it with a DMM to see. It is more likely an issue with flame recognition off the pilot/ignitor. Check them for rust that would cause a faulty connection.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 30, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool heater will not stay lit
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Apr 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Burner cycles on and off within 2-5 seconds. What could the problem be? Model Teledyne Laars LLD250N
Sounds like the flame sensor. If the sensor doesn't see a flame, it shuts off. Good luck...Lee
Oct 31, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
How to test an ignition assembly board for ld/125 laars lite 2 before replacing it.
this may tell me you dont know if the ignition control is not working. see the owner manual at jandy.com
Aug 26, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Heaters starts up (ignites) and shuts down in 2 secs
usually indicates a flame sensing problem. remove sensor and clean with steel wool .
Jun 23, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
May 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Laars Lite2 Ld 400,000 Btu Heater Logo
113 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
