Unplug it entirely from the wall,wait a while..plug it back in
Testimonial: "I already tried that and it didnt work.. Im afraid I need to replace something. It was working fine until I moved it from upstairs to downstairs, I thought maybe something jiggled loose, but when I tried to open up the television and look I couldnt figure out what could be wrong."
SOURCE: Mitsubishi turn on then turns off
Your model has the V22 chassis when it blinks a 21 cide which is what yours is indicating that maens the set is shutting down due to xray protection. Which means a votage is raising which trips the xray protection circuit and keeps your set from operating
1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR PROPER SEATING OF CONNECTIONS TO AND FROM THE HIGH VOLTAGE BLOCK. 2. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
SOURCE: Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
SOURCE: I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
SOURCE: Mitsubishi model Wt-46807 Power shuts
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
SOURCE: Mitsubishi Television Model: WS-65311 when
The error code 23 signals the loss of the horizontal deflection. The most likely part that has failed is the power deflection transistor and (almost always) the flyback transformer.
The parts will cost $80 and the labor about $150 - you will need to call a pro for that, the extremely high tension in there is very dangerous.
I tired that already Jerome and it still does the same thing.. any other solutions??
