My acer h223h monitor only shows the theme. It will not show anything else.
  • 48 Answers
This is caused by windows (or watever your OS is) thinking that your monitor is an external one
to fix this you need to go to display properties and select your monitor to be the primary monitor
Posted on May 28, 2009
ACER H223H
need more description does bios boot listen to see if the hd spins up
Jul 14, 2014 | Acer Computers & Internet
Aspire AX1200-U1510A starts but monitor doesn't show anything. Monitor works with an odl Dell.
If an old Dell monitor works with your computer then that monitor has something wrong with it.
Try to plug in the monitor to a wall outlet but do not plug it to your computer. If it still doesn't show anything, then you should replace it. You can contact the manufacturer of the monitor. You might have a warranty for it. They might fix it or replace it with a new one.
I hope this helps.
Carlo
Nov 20, 2012 | Acer Aspire X1200U1510A PC Desktop
My Acer X193w. My monitor comes on and says cable not connected but when I connect the VGA cable the screen goes black even though it is still on.
VGA is an analog connection, so you should connect it to your monitor BEFORE starting up the PC. Otherwise it won't show anything
May 04, 2011 | Acer X193W LCD Monitor
I put my acer aspire one laptop into standby by putting down the monitor which automatically lock the laptop but then when i use it again the monitor is dark and i cant see anything. the power is on and i...
ok, press the Power button on the Laptop once, and if nothing happens, press the power button again but this time hold it down until it goes off... then remove the battery for 2 minutes, after that put the battery back and press the power button, it should power on and the monitor will show. (Do not plug into power source during all the above process).
Bams Tech.
Dec 02, 2010 | Acer Aspire One Netbook 8.9" Notebook
I hav buyed a new acer v173 lcd monitor,and used upto 10 months till now.Lastday when i switch on my lcd,it showed the Acer logo , and suddenly the color of the screen changed,now the lcd works but i could...
Sounds like a problem with the video board of the monitor. I would contact Acer, since it less than 3 yrs old, tell them the problem that you are having get an RMA number and they will fix it for free. You only have to pay for shipping it back. Hope this helps.
Jul 29, 2010 | Acer V173 b Monitor
Image for first 3 secs... light still on green
correodemie, Your ACER AL2016 will need to have it's "switch-mode-power-supply/CCFL inverter supply" trouble shooted and repaired. DIY repair cost less than $30. Out of warranty service $35 to $75, more if circuit board replaced. Read my and other techs FIXYA profiles to discover all the options you have for your BLACK screen symptom. Follow the links to other web sites for even more useful info. DO THAT before you do anything else. 12fixlouie
Feb 03, 2010 | Acer AL2016 W 20" TFT LCD Monitor
Both screens wont work
No mention of how much ram installed ???
Are you using ACER GRIDVISTA
This program handles the multi screen out put
or
Standard Screen Properties,,,,,,,
Try this
DESKTOP>Right click properties
DISPLAY PROPERTIES>Settings
With both screens connected.
There should be two windows displayed ,
a highlighted white one and a grey one
Click IDENTIFY.
ONE SCREEN-
Should display a number 1 on the screen it has attached.
TWO SCREEN
Should display a number 2 on the external screen.
Once you get IDENTIFY to work then set resolution sizes of both individual screen.Apply and ok to save settings
If using GRIDVISTA then set the setting for the output functions and save theme as a theme BOTH or LAPTOP AND EXTERNAL MONITOR and its accessible from the desktop right click.
Good luck I have a couple of these I use for my Media Centre wirelessly networked thru the house.Great machines.
Jan 11, 2009 | Acer Aspire 3680 Laptop
Acer monitor does not show anything except acer
"have three and same problem on different computers"
- you have 3 what? If you tried 3 different computers with the same monitor, your monitor might be bad and need repair. If your computer works fine with a different monitor, then it is your monitor that is the problem.
I do not recommend hat you attempt to fix monitors on your own.
Dec 06, 2008 | Acer AL1716 F Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Acer al1916
try changing with the bios settings
Aug 28, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
367 people viewed this question
David Payne
David Payne
