Question about Sharp UX B700 Plain Paper Inkjet Fax
How to recieve faxes have no manual please help
We were given a brother fax 727 telephone fax machine but with no manual  we need help on how to recieve faxes
thank you
  • ubu2003 Nov 15, 2007
    I can receive faxes but only if I manually answer and hit Start. Is there a way to set up an auto-answer for if I'm not home?
  • 87 Answers
Go in the menu/or options mode ,find receive and select auto mode.
Posted on Oct 24, 2007
How to recieve a fax threw brother MFC210C
Unlike many all-in-one units, this one can be used as a stand-alone fax machine, not requiring you to use fax software in your computer. Make sure you have a telephone line connected to the LINE jack on the side of the machine, and that you have gone through the fax setup steps in the manual. You can download the manual and a quick setup guide from Brother here if you need a copy. Once the machine is set up and on a phone line, receiving a fax is automatic when someone calls in.
If you are having some specific problem setting up your printer or something is going wrong when it's trying to send or receive a fax, please post a follow-up comment with more detail about the trouble. I'll try to help further if you need it.
Mar 08, 2011 | Brother MFC 210C All-In-One InkJet Printer
Tad up on the screen, and it will not allow us to recieve a fax.
TAD on the screen means Telephone Answering Device. Check your users manual for correct set-up...if youve lost manual go to www.brother.com there are manuals there to download. In their SUPPORT section.
Jan 12, 2011 | Brother MFC-9070 Plain Paper Laser Fax
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
Brother fax model 575 in Manual recieve Mode,won't change
Telephone Answering Device (TAD). This is the mode you use when you have answering machine active on your phone line.
Mar 27, 2009 | Brother FAX-575 Plain Paper Thermal
My machine stopped recieving faxs.
Not familiar with the procedure to set your machine, so refer to your manual if need be, but somehow you machine has been chnged from "automatic receiv" to "manual receive", or "telephone mode".. Setting obviously needs to be "auto" for the machine to pick up on it's own.
Often times, this is a button right on the operation panel that you can toggle between the different settings.
Feb 24, 2009 | Brother Office Equipment & Supplies
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
How to send and recieve faxes
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_775_EN_86.PDF
Aug 01, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Sharp UX B700 Plain Paper Inkjet Fax Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
