Question about Black & Decker String Trimmer Cordless 12" 18V
Can not undo the lock nut
Black and Decker Strimmer GL630 Can not remove lock nut to replace damage belt.
  • 313 Answers
SOURCE: how to thread a strimmer
the spool itself had a direction how to wind the string.
Posted on Jun 02, 2008
SOURCE: how can i repace the
Instructions can be found at: https://www.2helpu.com/PDMSDocuments/EU/Docs//docpdf/gl550_uk.pdf.
If the line keeps getting too long, it's because swivel 14 in diagram 7 was in the wrong position when you inserted the spool - just move it to the ouside position, re-insert the spool and away you go. Frankie.
Posted on Jun 11, 2008
  • 9 Answers
SOURCE: how do u rewind a
if it is going back onside or unwinding it proble is in upsidedown or wond backwords
Posted on Jul 30, 2008
  • 4 Answers
SOURCE: got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Posted on Jun 01, 2009
#1 Taper
  • 1040 Answers
SOURCE: threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Posted on Jun 21, 2009
How to remove impeller from black and decker leaf blower
the nut or if no nut , the thread is left hand so hold the shaft and do it up to undo it ( clockwise direction)
Dec 05, 2016 | Black & Decker Garden
Black decker troubleshooting
ensure the spool is not ended if so replace with new spool of string. also check the retaining screw in the middle is not too tight. undo it one click at a time to alow the spool to unwind when the motor runs
always disconnect your strimmer from the power when doing this also wear protective footware and long trousers, when using such tools.
May 20, 2014 | Black & Decker Irons
Fit new chain to gk1000 black & decker alligator
lay the machine on its side motor side facing downwards undo the 2 nuts that hold the cover on then remove cover, pull the chain bar backwards the remove the chain replace the chain making sure that the chain cuts in a clockwise direction then put cover back on, put nuts back on finger tight tension the blade by turning the flat bladed screw clock wise then tighten the 2 nuts up full..
Dec 01, 2010 | Black & Decker Garden
Cannot undo nut on bottom of Strimmer
Make sure you are turning the nut to the right to loosen, if you are already doing that but cannot hold the line head still to loosen the nut some feature a hole to insert a screwdriver or pin (supplied with the trimmer) or if yours does not have that: use a nylon strap or even a leather belt to wrap around the head, and then clamp the loose end in a vise or quick clamps and it will hold it in place well enough to loosen the bolt.
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
How to restring a black & decker gl 565 strimmer
Hi Bill,
If you turn it upside down you will see the strimmer head. You should be able to remove the protective cover which will allow access to the string cassette. The rest is self evident.
Feb 14, 2010 | Black & Decker Garden
How do i replace strimmer wire on a black and decker 315
how do i replace a spool and line on a black and decker GL20 strimmer x
Sep 10, 2009 | Black & Decker Garden
How do i refill spool
how do i undo spool on black and decker auto strimmer d825
Jun 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
BD GL720 strimmer
Yes it can be repaired Jim. The belt has probably snapped. It happened on mine. Just undo all the screws and one hidden screw underneath the black lable near the number one, which is on the same side as all the other screws. Run your finger over the lable and you should feel it. Just pull the telescopic arm out and lift up the motor slightly so that you can place a new belt on. Simple as. Hope this helps
Jul 10, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
205 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
