Question about Shure Beta 52A Professional Microphone
Beta 52 distorts
Seems to cut out and distort
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Contact Shure for repairs.
Posted on Jul 27, 2014
2 Suggested Answers
SOURCE:
  • 611 Answers
SOURCE: My sm58 beta distorts.Is the mic element hard to
If you know how to use a soldering iron, the element is easy to switch out. However, it is probably less expensive to send the mic to Shure. That is the cartridge might cost more than the flat fee repair charge that Shure Service charges.
Posted on Jun 18, 2010
Radios keep cutting out.
Check condition of antenna on problem devices, look for cuts or abrasions on plastic covering and check they are screwedin tight. Are some of them encrypted ? And is there another radio source in building or area you cover. Near TV reciecevers is know to cause distortion and keeping antenna upright, horizontally effects range.
Apr 03, 2014 | Motorola Radio Communications
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
THE COLOR IS DISTORTED AND THE TV SHUTS OFF
Possible misalignment or fault in the RGB output. If the set is cutting off in a determined time then there is some compoent that is heating up to shut off the set.
Identtify after opening and use a fan to cool to prolong the shut off time. The pinpoint the component that seems to work off in thermally.
Sep 12, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The color is distorted and the picture blinks. I've replaced the lamp twice before and i don't think this is a lamp problem.
color distortion (bleeding colors, or overwhelming of one color)on these tv's is commonly the optical engine. that might make it unecinomical to repair
Mar 27, 2010 | Toshiba 52HM95 52" HDTV Projection...
52 inch RCA Home theater-Sound is distorted/scratchy
I unplugged the tv for 5 minutes. When I turned it back on, I had sound!
Aug 01, 2009 | RCA 32V420T 32" TV
GE D52GW12, picture is distorted and snaps
its either the HV splitter or the flyback which needs replacement. You can get both items at the following link with free instructions.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Picture flutters and distorted
Capacitors going bad on your DM or FMT board. Very difficult to replace, but Mits does a rebuild on the chassis. I recommend talking to your Mits service center and getting the rebuild done.
Dec 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
Distorted picture
i was just working on a set with the same problem .. i found a east west correction curicit with a falty transistor. something in that cuircit has failed.
Jan 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shure Beta 52A Professional Microphone Logo
59 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
