Question about Breville Die Cast 800ESXL Espresso Machine
Breville expresso filter
Double shot filter cleaned but does not allow coffee to come through. Tried pushing cleaning pin through but still no coffee comes through. Single filter is fine.
  • 3 more comments
  • rbeaston1 Dec 18, 2007
    Both coffee filters do not allow coffee to come through. This is frustrating considering I spend $400 for a coffiee machine that does not proeuce coffee after 1 month of use.
  • drv5 Dec 21, 2008
    Yes, I have the same problem with both 1 & 2 cup baskets. I suspect that I'll have to have my coffee in a more corse grind.
  • jfboylan Dec 31, 2008
    cleaning the double shot basket does not allow the coffee to come through. Single shot basket still okay, but we haven't used that one (til now.)
  • Anonymous Jan 16, 2009
    i can't get the single pod to fit into the filter
  • tommynick99 Mar 02, 2009
    basket fills with water. Coffee comes out slow. liquid fills up tank underneath
Put the coffee filter in the oven (yes the OVEN) and run a auto-clean cycle, it will turn all to hashes. Run a clean water cycle after to clean it.
It may discolor the filter a bit, but this is only cosmetic.
It happened to me because the grinder at the grocery store had trouble without anybody noticing it. It's then I decided to buy my own grinder.
Good luck,
Posted on Oct 17, 2009
    Problem Solver:
  • 7 Answers
The same thing happens to mine when I grind the coffee too fine. Try grinding a bit coarser, and pack extra grounds in. Amazing coffee when you get it right, and the grounds aren't runny with the coarser grind.
Hope this helps.
Posted on Dec 02, 2008
Soak in white vinegar. if that doesn't work get a new one on
Posted on Dec 01, 2007
  • Helen dillwynia
    Helen dillwynia Feb 16, 2014
    No! these answers do not help. If the coffe was incorrectly ground I would have had trouble whether the filter holder was wet or dry and I Only have a problem when the filter holder is wet.
Group head not running
Perform a full descale. Take out the water reservoir and remove the Anti-calc filter. Put in 500ml (1 pint) water with 3-4 tablespoons of white vinegar (or apple cider vinegar). Put the water canister back in, the turn on the machine and press the manual button. Allow half of the liquid to go through, then stop. Leave the machine for about ten minutes, and then run the rest through. Empty the water reservoir and rinse, put back the Anti-Calc filter, put in another 500ml and press the manual button to flush it all through.
May 11, 2014 | Sunbeam Cafe EM6910
My Breville Expresso machine does nothing when I turn dial to make coffee
Sounds like its time to clean it. Run white vinegar and a little water through it.
Apr 18, 2012 | Breville Coffee Makers & Espresso Machines
My steamer on my Breville Die Cast Expresso machine no longer works, I have cleaned it, soaked it in vinegar. Any ideas?
Pleas do not soak this in vinager, try this process with vinager and most cost efficient way to fix this issue with HEAD SPRAYER HOLE clogging is to run vinager through the system several times. The compounds in the vinager serve as a cleaning agent to clean the heads naturally and allow the coffee to travel once again in the same holes it did when you first purchased the unit!!! Just fill up the pop with straight vinager and allow it to run through the system just as if it was coffee! This WILL NOT have any harmful affects to you or the coffee system unless you are allergic to vinager.
Jan 21, 2011 | Breville Die Cast 800ESXL Espresso Machine
How many oz of expresso when making a 2 cup with the machine in a measuring glass . i bought two measure shot glass to make a perfect cup of latte. i know it says 24 seconds
For every cup of espresso we mean about 25cc to 30 cc and you have to use from 7 to 8 gr of groud coffee per cup according to the coffee blend and how strong you wand the aroma of your coffee. The running time for making either one cup or two cup with apropriate filter is about 24 to 30 sec maximum.
Good luck
Apr 18, 2010 | Breville ESP8XL Espresso Machine
Krups K2 XP402040 Expresso maker. This makes the
Would you like to try not put too much coffee powder, and not make the coffee powder too firm ( I mean not press them too heavy.)
Or, not grind the coffee powder too thin....
Hope it helps you.
Oct 30, 2009 | Krups Coffee Makers & Espresso Machines
Water on top of the filter after brewing
my experience with this machine is that this varies greatly with the type of beans you use. I would experiment with a few types of beans, roasts, and you might get lucky.
Nov 28, 2008 | Breville ESP8XL Espresso Machine
Cafe Roma Expresso/Cappucino machine
My understanding is that this is normal with units like the ESP8XL which use a pressurized portafilter. Non-pressurized units will leave a dry puck of used grounds.
Hi All. I too was having this so called exploding issue with my machine & couldn't get any coffee!! The culprit is a clogged filter!! As you might know, Breville uses a double wall construction for the filter which incorporates an inner cup with many fine holes and there is only ONE small hole on the bottom of the outer wall(bottom). I guess over time some fine fine grounds get thru the inner layer and accumulate between the two layers and eventually get compacted enough to completely clog the filter to a point that the pump cannot push the water through it!! Thus the pressure from the pump can't escape & is releasd when you try to remove the coffee basket!! You can try to use a small pin inserted in the bottom hole to see if it clears the obstruction. It didn't work for me! I even tried using high pressure air to clear it, again unsuccessful!
THE FIX: Buy a new filter!
P.S. I found my machine to have some build up behind the strainer where the water enters the coffee chamber. To clean and clear, follow these steps: Unplugg the power cord!! Remove the watertank. Remove the filter holder. Turn the machine upside-down, Remove ONE screw in the center of the coffee chamber(It looks like a strainer with several holes). Remove the strainer and wash & clean any build up behind it. Reinstall in reverse order.
Sep 20, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Cafe Roma does not pump, or build up enough pressure to push the water through the coffee. Help.
Make sure the filter is clean, that in the holder and in the machine. If it is clean then i think your pump have to be replaced:-(
Jul 21, 2008 | Breville ESP8XL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
933 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
