Question about HP Compaq Motherboard
Hp a705w desktop (pc on fan on but no signal to other locations)
Got from friend,turn power on the 2 fans is running but no signal to monitor,mouse,keyboard,usb,etc.only the dvd rom work.There are no beeping to tell something are missing when turn on.What should be the problems?DEAD CPU or MOTHERBOARD.Some advice please,thank you.Patrick.
P.S I unseat & install the ram, clean all the dust out, take out the motherboard to inspected but see nothing suspecious,and install back on.Nothing happen only the 2 fans are running.
  • 489 Answers
Motherboard is broke downs. not responding even beeps. mostly we dont see anything suspecious when we look at the mainboard. we are talking about micrro technology.
take the service to get assist.
have a good evening.
Posted on May 28, 2009
  • HP Master
  • 4,806 Answers
Hi there.
The best way to check if the processor is at fault is turn the machine on for a couple of minutes, then turn it off.
Disconnect the CPU fan and heatsink and feel the processor, if its warm or hot then the processor is fine.
In most cases its the bios chip which is down so if you can clear the CMOS or remove the power cord from the back and take the motherboard battery out for half an hour.
See if that gets you anywhere.
Good luck and thanks for choosing FixYa!!
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
We moved the desktop to another location. We powered down and unplugged it. When we plougged it back in there was an alarm that went off then the power button started flashing and continues to do so. We...
hi t could be that your CPU fan is loose or that your RAM(memory) came loose try looking on youtube to see how to put RAM (memory) into pc and make sure your CPU fan is secure....bonnell
Sep 17, 2011 | HP Pavilion a705w PC Desktop
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
My son bought an HP a705w 3 weeks ago. The thing worked fine at the home where he got it, I was there with him. He got it home and removed the cooling fan from the video card(which I told him NOT to do!)He...
Locate the VGA connector (encircled in red) at the back of the PC:
Plug the monitor cable in it and start the system. If its functional the display should come.
Remove and re-install the RAM. It helps sometimes. Remember to un-plug the system from the mains before carrying out this procedure.
I checked the mother board specs (HP A705W) and it has no external video card slot nor any fan except on the processor. Did your son put a PCI video card?
By the way, it isn't wise to remove the fan if there is any on any device. Not only the device will be damaged but can result in a fire hazard as these components get VERY hot during working.
If the after reinstalling the RAM, PC does not boot, its likely a hardware fault. You have to get it checked by a tech. If its not repairable a new board is required and make sure that other components are working before making a purchase. Mother board model is MS-6577.
Apr 01, 2010 | HP Pavilion a705w PC Desktop
Hp pavilion a705w. no peripheral response
The fact is *********** board is very likely the matter. See all devices that do not need the motherboard to respond are all working (cd/dvd tray opens and closes, fans are on etc). On the other hand all devices that need the motherboard to respond are not working (keyboard, optical mouse, etc). It is more or less conclusive.
Dec 04, 2009 | Computers & Internet
Hi I have a HP Pavillon a708 and the fan is almost constantly on. It's really noisy and seems to slow the PC down, is there anything I can do??
First, open up the case and gently vacuum all the dust, especially around the 2 fans.
If still noisy and the problem is the cooling fan (3-5 inches across), buy a replacement fan of the appropriate size at a PC store for $30 - $40. It takes 5-10 minutes to unscrew the old fan and install the new one, and just use the same electric wire from the old fan for the new fan.
If it's the CPU fan, you'll need to have your PC serviced.
Hope this helps.
Jul 09, 2009 | HP Pavilion a705w PC Desktop
Cpu cutts off every 30 secs
hiya
it seem as as tho ur cpu is over heating...... take the case off and have a look to see if the cpu fan is turning if not theres your problem......
if it is turning it cud be the fact that the cpu isnt getting enuff power or too much...
is the cpu overclocked at all....
Feb 23, 2009 | HP Pavilion a705w PC Desktop
Hello I have a hp pavillion a705w it wont turn on any monitors
How Would I Go About Hooking 2 Monitors Up To My a705w
Jan 18, 2009 | HP Pavilion a705w PC Desktop
HP Compaq Motherboard Logo
152 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
