Question about General Electric Microwave Oven
Sparks ae flying in my microwave
Sparks are flying in my GE Convection Microwave Oven model JES1290SK . There is a piece of cardboard on the inside right wall, about 3x5, which is hard to clean due to it being posterboard.I was told by GE that this piece can not be replaced and if the sparks are coming from it, not to use it. It is barely one year old and past the one year warranty. What a I supposed to do with this;throw it away?? Any sugestions? Thanks, Sandi
  • Samuel Charles Spriggs May 11, 2010
    Do I understand that you think the sparks are coming from that piece of cardboard because it's dirty and the grease/whatever is burning off?
    Does this piece of carboard have a silver colored coating on it?
    President:
  • 3,433 Answers
GE in essence says it is unrepareable and insafe. I suggest that would be saying it is trash.I don't know what that carboard is, possibly indulation? Ot may have /be a a oiece oce of laminated metal like some paper plates have..Not replaceable is a poor answer. Call them back and make a fuss. If it's not too far over warranty, they may work with you to shut you up.. oops, sorry, to pacify you.
:-) Good luck.
Posted on May 28, 2009
JES1290SK No power when on. Display works, work light works until enter is pushed. No motor movement
Does the convection work? If so likely you need a magnetron If the control panel is having problems then it needs to be repaired or replaced. It could be just a stuck relay inside so a firm hit may release it
Nov 27, 2013 | GE JES1290SK 1.2 Cu. Ft. Countertop...
Microwave sparks
If it sparks inside the oven then look inside for any powder paint missing... if so discard. If you has metal shelves or tin foil then don't put metal in when on microwave setting. Some of these metal shelves are for a microwave that is also a convection oven but only in the convection oven setting.
Nov 26, 2013 | Thermador Microwave Ovens
My GE microwave convection oven JVM1790SK 01. It has started to make a load grinding noise, and is sparking above the cavity area, otherwise it operated properly. When I remove the fan assembly part...
The fan is for air circulation regulation, e.g. preventing steam (and smoke) from building up inside, and also stops air pressure from building up inside so you won't get a blast of steam coming out or worse. On the convection side it heats the food faster and more evenly. You will need to replace the fan assembly to keep the microwave safe. the noise and sparks are probably due to spent bearings and / or a dislodged fan scraping against another surface or something getting in the way of the fan
Nov 30, 2017 | GE JVM1790 Convection / Microwave Oven
GE JES1290SK microwave magnetron is arcing
I don't know about a recall, but if your unit is under warranty parts and labour are included in most cases.
Sep 03, 2012 | GE Microwave Ovens
My microwave/convection oven (a GE unit model JES1290SK) started beeping every few seconds and displaying F6 on the control panel. I unplugged it and waited several minutes and when plugged in it displays...
The technical sheets in my files do not list F6 on the error code chart for GE microwaves.
Generally, these are the error codes possible on GE microwaves:
F1 open thermal sensor (convection models)
F2 shorted thermal sensor (convection models)
F3 key panel shorted for more than 60 seconds
F4 open humidity sensor
F5 shorted humidity sensor
There should be a "mini-manual" (technical sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 15, 2011 | GE JES1290 Convection/Microwave Oven
Sparks when on microwave cooking
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kk
Apr 09, 2010 | GE Advantium 120 Convection/Microwave Oven
I need the glass turn table asap. and how much does it cost? for jes1290sk
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=WB49X10174&productGroupId=0022&supplierId=364&brandId=0432&documentId=G0606370&keySuffixId=NA&modelNumber=JES1290SK02&keyId=1508&pageId=00001&productTypeId=0123245&searchModelNumber=JES1290SK02&subCompDesc=Microwave&brandDesc=GE&modelDesc=MICROWAVE&blt=11
Unless you can find one someplace else cheaper.
Eric
Dec 11, 2009 | GE JES1290SK 1.2 Cu. Ft. Countertop...
We have a ge microwave. Sparks came out of
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the mica waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
Sometimes it is the ceiling of the oven.
Your owner's manual may address this. You can download GE owner's manuals and installation instructions here.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.AC
Oct 10, 2009 | GE JES1290SK 1.2 Cu. Ft. Countertop...
Oven will not work; has no power due to power serge from local utility. Is there a fuse inside the oven? GE repair men says bring in to shop;the manual says laymen should not atempt repair, but the cost of...
hi my name is mark, most microwaves have fuses in them. if you are comfortable taking things apart you can fix it. you will need hand tools, a meter to check the fuse. radio shack sells inexpenive ones. unplug the microwave when you disassemble oven. first make sure the circuit breaker to the oven is not tripped. hope this helps. thank for your question.
Mar 16, 2009 | GE JES1290SK 1.2 Cu. Ft. Countertop...
I recently bought a microwave/convection oven. Model #JES1290SK 02. I understood that cooking time would be lessened for most recipes when using the convection oven, but it takes longer every time....
GE Customer Service is here, and they should be able to help you.
They may refer you to the Answer Center.
Aug 12, 2008 | GE Microwave Ovens
General Electric Microwave Oven Logo
314 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
