Question about Westinghouse Televison & Video
How do i get rid of parental control
My grandson was playing with the remote control and entered some code and we cannot get rid of the parental control. What solution can you give me.
  • 1,959 Answers
If it's the remote control that's locked, you can remove the batteries for about 30min. This should erase whatever lock has been put in place. If the lock is on the cable box, then you can contact the cable provider, explain your situation and ask for the lock to be removed. Hope this answers your question. Best of luck.
Greg
Posted on May 28, 2009
I BOUGHT A SONY DVP-NC665P AND WHEN I START TO TRY AND PLAY A DVD IT IS WANTING A PARNTAL CONTROL PASSWORD . CAN YOU HELP?
Enter "199703" by numeric keys of remote control when dvd player ask for parental code and press Enter to reset old code, then put new 4 digit code (like 0000) then go to set up menu and turn off parental control.
Thanks.
Oct 27, 2010 | Sony DVP-NC665P/S Multi-disc DVD Player
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
I am trying to play a dvd and it is asking me for a code or password, I never set one I have played the dvd player before, so this is a puzzle.
There are a few different "default" codes that you can try.
0000 or 1111 or 1234 or 9876 etc.
Here is something that i just came across, I do not know if it will work but it maybe worth a try:
1. Turn the DVD player on with No Disc in.
2. Press MENU on the remote (Ignore the 'NO' symbol that appears)
3. With the remote, press 1, then press 9 (Ignore the 'NO' symbol that appears)
4. A menu should appear.
5. Use the Down Arrow to highlight the PARENTAL CC then press ENTER. Now type the Parental Control setting you want with the remote (8 is the highest setting, press 8 on the remote for a fully unlocked player). Then press ENTER on the remote after entering your new setting.
6. Use the Down Arrow to highlight the PARENTAL PW. If you wnat to change this, press ENTER. You can enter any 4-digit code here. Press ENTER on the remote after you enter the 4-digit code.
7. To exit the menu and save your settings and push OPEN/CLOSE with the remote.
Feb 12, 2010 | Philips Televison & Video
Original xbox parental controls
You need to have the DVD dongle that plugs into the front of the Xbox in order to play DVD's. If you do have that, any universal remote should work on it, I use a GE AllinOne universal with mine, I think the program code is 000 or 0000.
Or, if its the lock thats getting you down...
Here is the procedure to reset the parental lock code:
  1. From the XBOX dashboard screen, go to settings and then parental control.
  2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
  3. Enter in a new password, or disable parental control entirely.
Hope this helps!
Jan 09, 2009 | Microsoft Xbox Console
The parental lock is on and I don't know the four digit password
My husband was playing with our remote and accidently put parental lock on. We could play cd's but not dvd's. Here is what I did. Go to the set up menu. Arrow over to the parental control and press enter. Arrow down to where to put your password in. Enter 0000 this is the factory default code. It will ask you to enter it again. then return to the main menu. I turned mine off with the remote then turned it back on, put a dvd in and it worked. My husband was ready to go buy a new dvd player. Power to the women!!! Hope it helps you.
Sep 01, 2008 | GE1401P DVD Player
Parent control lock
The parent control lock out code is 1234, you need to press yes then enter the code using the remote type in 1234 then press play button again and it unlocks the parent controls!
Jul 07, 2008 | Disney Princess DVD Player
Zenith DVD Parental Lock
Try power on the player with no disk in the drive. Press "PAUSE" on the remote. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display). Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.) . Press "PAUSE" on the remote. Power the player off and then back on
Feb 17, 2008 | Zenith DVC2200 DVD Player
Parental control code
ok first go to the DVD setup which should be located near the bottom of the remote is says SETUP. Then it will give you a list of options go to the one with the parental code one. Then you should try and change the password. My tvs old password was 8888 but I am not sure if it is the same on all tv's. If it is right then you should be able to change the password to whatever you want! I hope this helps anyone who sees this response!
Sep 09, 2007 | Aiwa VX-S207 20 in. Combo
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
Televison & Video Logo
390 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
