Question about Kitchen Ranges
After self cleaning cycle completed and oven had cooled we attempted to set the oven to bake. When we set the oven temperature the stove starts beeping and displays error code F3.
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
F3 error Codes means Open Sensor circuit Open (blown) sensor fuse or bad Sensor.
Check the oven sensor resistance at the control board plug.
It suppose to be about 1100 Ohms at the room temperature.
If the reading there is wrong, check the sensor resistance at the sensor plug and the wire harness.
If there is nothing wrong then replace the control board.
Let me know for further clarifications
Posted on May 28, 2009
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Oven (indicator light) clicks on and off
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
Nov 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
How do i start self cleaning oven
To Self-Clean:
1. Press SELF CLEAN to set the clean time to HI (4 hours
30 minutes).
2. Press the TEMP/TIME "+" or "-" keypads to cycle between LO
and HI clean time.
3. Press START.
The oven door will automatically lock. The CLEAN indicator
light will be displayed. The time remaining will also be
displayed.
4. When the self-clean cycle is complete and the oven cools, the
CLEAN indicator light will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth
Remove the broiler pan, grid, cookware and bakeware, all
cooking utensils, oven racks and aluminum foil and, on some
models, the temperature probe from the oven
Dec 07, 2012 | Maytag MGR5751AD Gas Kitchen Range
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
Lost Manual and would like instruction on how to set for self clean cycle?
Make sure you have everything out of the oven, including the oven racks.
1. Press SELF CLEAN.
2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
3. Press START.
The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
displayed.
4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
indicator lights will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth.
Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
It is also recommended that you remove anything plastic from the top of the stove during cleaning.
Nov 27, 2010 | Whirlpool RF263LXTQ Range
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
How do use self clean service?
CAUTION: SHOULD AN OVEN FIRE OCCUR,
CLOSE THE OVEN DOOR AND TURN OFF THE
OVEN. IF THE FIRE CONTINUES, USE A FIRE
EXTINGUISHER. DO NOT PUT WATER OR FLOUR
ON THE FIRE. FLOUR MAY BE EXPLOSIVE.
To set the controls for a self-clean cycle:
For satisfactory results use a 2 hour self-clean cycle for
light soils and a 3 hour cycle for average to heavy
soils.
1. Be sure the clock shows the correct time of day.
2. Press Clean. "— — —" appears in the display.
3. Press the Up Arrow until "3:00" appears in the
display for a 3 hour cycle, or press the Down Arrow
until "2:00" appears in the display for a 2 hour cycle.
4. As soon as the Up Arrow or Down Arrow is
released, "CLN" appears in the display.
5. As soon as the controls are set, the motor driven
lock will begin to close automatically and the "LOCK"
indicator light will flash. DO NOT open the door while
the light is flashing (it takes about 15 seconds for the
oven door to lock).
6. The "LOCK" light will glow until the cleaning cycle is
completed or cancelled, and the oven
When the self-clean cycle is completed:
1. The time of day or “END” will appear in the display
window and the “Clean” and "LOCK" light will continue
to glow.
2. Once the oven has cooled down for about 1 HOUR
and the "LOCK" light has gone out, the oven door can
be opened.
3. If “END” is in the display and the “Clean” indicator
remains on, press Clear/Off. The time of day will
appear in the display.
NOTE: When the oven is cool, wipe away any residue
or powdered ash with a damp cloth or paper towel.
Stopping or interrupting a self-cleaning cycle:
If it becomes necessary to stop or interrupt a selfcleaning
cycle.
1. Press Clear/Off.
be opened.
3. Restart the self-clean cycle once all conditions have
been corrected.
How the ES 200 operates:
CAUTION: NEVER ATTEMPT TO REMOVE EITHER
THE BAKE OR BROIL ELEMENT WITHOUT DISCONNECTING
ELECTRICAL POWER FROM THE
RANGE. ELECTRICAL POWER IS CONNECTED
TO THE ELEMENTS WHENEVER ELECTRICAL
POWER IS CONNECTED TO THE RANGE.
The ES 200 electronic oven control system is made up
of three parts that control the bake and broil elements,
and the locking of the door in the self-clean cycle.
1. Electronic oven control.
2. Oven temperature sensor.
3. Oven door lock mechanism.
Dec 06, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Self cleaning
You can go to the Maytag web site and download the manual.  www.maytag.com, or go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
and download the manual CAUTION
• It is normal for parts of the ovens to become hot during a self-clean cycle.
• To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
• Avoid touching doors, windows or oven vent area during
a clean cycle.
Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
Do not leave baking/pizza stone in the oven during self-clean.
The self-clean cycle uses above-normal cooking temperatures
to automatically clean the oven interior.
The oven should be cleaned regularly by wiping up spillovers
to prevent excessive smoke and flare-ups.  Do not allow a
heavy build-up of soil to accumulate in the oven.
During the cleaning process, the kitchen should be well
ventilated to get rid of normal odors associated with cleaning.
Before Self-Cleaning
1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
cycle.  (The gasket is the seal around the oven door and window.)
4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
Important:
• Oven temperature must be below 400° F to program a clean cycle.
Only one oven can be cleaned at a time.
• Both oven doors lock when either oven is being cleaned.
To set Self-Clean:
1. Close the oven door.
2. Press the Clean pad.
    • CLEAN flashes.
    • SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
    • “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning settings.
     “HVy” (Heavy Soil, 4 hours)
     “MEd” (Medium soil, 3 hours)
     “LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs the self-cleaning time.
5. After four seconds, the oven will start cleaning.
    • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
    • CLEAN will appear in the display.
    • LOCK will flash in the display.  Once the door locks, LOCK will
      remain steady.
    • The cleaning time will start counting down in the display.
Nov 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
90 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
