I can start it a leave run and it will die after a while when driving if I take my foot of gas it dies so I have to hold break and push in gas a little to keep running what might be wrong
SOURCE: 1999 Cadillac STS
first u have to ask yourself what type of maintenance have u done via fuel filter ect,,get presure on rail check if it does not read right check regulator if you here an irreguler humm from your fuel pump will usually give you warnnin it is going out with change of this filter. I recomend!!!change the regulator with this repair.
SOURCE: 2000 catera cold start idles rough and dies. After
Did you have battery disconnected or dead recently?
Try to place ignition in run without starting engine for 3 minutes (shut off all accessories and lights etc..). Then shut it off and then start it. Should relearn the idle.
If this doesn't fix the problem, unplug the MAF sensor, if it runs fine with it unplugged, its the MAF sensor.
Exactly what happened on my wife's 01'.
