Under normal printing 8 1/2 X 11, I have no problem. When choosing smaller print sizes epsecially borderless prints or best photo both the red lights for ink and paper start flashing, the green light goes out and the printer screen reads "paper jam" although there is no paper jam and media is loaded properly. Also if I attempt to print on a CD/DVD the printer feeds it in partially, the printer head goes back and forth a couple of times and then the printer kicks the CD/DVD back out. This doesn't seem to be a coiunter problem. The printer is about 2 years old and has printed about 5 thousand sheets. Any solutions?
1 Other User Has The Same Problem
Comment by vermontmtns, posted on Feb 10, 2008
I have an Epsonr R1800 as well. In Dec 2007 I started getting a paper jam error (both red lights flashing), though paper was not jammed. After purchase of the Epson Service manual and Epson Service program, I believe the error is:
Fatel Error code: 61
PW sensor error
The procedure to fix this is removal of the printer head, and cleaning and/or replacement of the PW sensor (this is the sensor that detects the paper edges, and also the CD printing assembly when being used). I have removed and installed Epson printer heads before, but on the R1800 some specialized tools are required, which if purchased from epson exceed the cost of two R1800 printers!
I posted more at: http://www.fixyourownprinter.com/forums/printer/53027
Any advice?
Rating: 0%, 0 votes
http://www.inkrepublic.com/KnowledgeBase/R1800PW.asp
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for Epson Stylus Photo R1800 InkJet
Email this problem
Can you Help with these Printers problems?
EPSON 1800 PROBLEMS WITH NEW...
paper wont feed
How are you doing it?
Failure of an Epson Stylus R...
