Question about Kenmore 5.7 cu. ft. Coin Operated Electric Dryer
Dryer started, ran 10 minutes stopped.
Breaker is on, vents are clear, door is closed
  • 15,935 Answers
Check the thermal fuse for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
An expensive fix? Time to buy a new dryer?
Depends on what the problem is.
Is it electric or gas?
Is it getting power to the control panel? Check circuit breaker.
Does it start after cooling down? Clogged vent hose.
Is the start switch or door closed switch damaged?
Can you turn the drum by hand? If not bearings, glide pad or motor.
With the controls set to run, turn the drum while depressing the door closed button and see if starts. Start capacitor bad.
Thermal switch bad? Check with ohm meter.
Normally in the middle of a cycle I would pick Clogged vent or circuit breaker. Both cheap do it yourself repairs.
Jul 16, 2015 | Dryers
Machine will not start, replaced start switch now machine starts with the hot and warm button i think i have got my wires crossed
the start switch will just have a hot wire,, with a momentary closing when you push the start switch,, if you list the make and model of your machine, I'll try and find the wiring sequence for you
Jun 30, 2011 | Dryers
Started then stop and wont come back on. circuit breakers checked, all wiring checked, door closed. light on inside on, could the start stop switch be defective?? dryer is about 10 years old. DRYER...
yes could be start /stop microswitch...firstly make sure fuse ok in plug also feed ok lastly ensure post to operate door switch has not broken off........hope this lot helps.....
Jan 14, 2011 | Dryers
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Our dryer ran for about half an hour and then stopped running I opened the door shut the door and you can hear the timer but when you go to push the button to start it it will not start. Any suggestions?
sounds like the overheat circuit breaker popped for safety. when the unit cools it will work again. most likely problem is your vent out is blocked, or lint filter full. once i found a birds nest on the exaust outside lol.
Jun 14, 2009 | Maytag PYE2300AY Electric Dryer
Sears Kenmore 08980800 Stops after 10 minutes of operation.
Sounds like the motor may be getting hot and kicking out on the motor overload switch. When it cools down it will reset.
Jun 10, 2009 | Dryers
Dryer does'nt run. checked breaker, thermal fuse, starter relay, timer stops when door is opened, starts when closed?
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
Apr 21, 2009 | Dryers
My Kenmore electric dryer won't start... I just ran it and it ran fine. Went to start a new load and it wouldn't work. Checked breaker, plug and door switch; everything seems okay
eazy first.need 220 if got,door switch it wiil click when depressed.next check where cord attaches.then the thermoal fuse.if has back panel or no same info.i call them missiles or flying saucers[thats what they look like].there white small have two wires to them.if you put the two wires too gether and isolate them,if problem your dryer will start,replace,but its a thermal fuse so the idea is if it gets to hot they open to stop fires,so mcheck all venting and dryer air waysGod is good,tom
Jan 02, 2009 | Dryers
Whirlpool Dryer stopped mid cycle and won't start again
This sounds as if the internal fuse has blown. I am assuming you have checked the breakers as well. The starter switch might be bad.
Dec 24, 2008 | Whirlpool LER4634J Electric Dryer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
