Question about Maytag Washing Machines
Maytag Insignia wont spin or agitate. Think is the belt how do I remove front panel to check?
Maytag top load insignia washing machine stopped working. Tub filled with water but no spin or agitation. Had to remove/drain water by hand. When on the machine makes a low grinding sound but no spinning/agitation. Also a smell of rubber is present when placed in the one position.
  • 4102 Answers
SOURCE: Maytag washer
Hi the problem will be the belt has become streched dont keep trying to use the machine as this will cause the motor to fail usually it is the back of the machine that will need to come off once this is off you will see how the belt comes off it is really easy to do and most people who can use spanners can do this with no problem.
I would say it is the back that comes off the best thing to do is take the belt off and take it to repair shop so they can order you the correct belt.
Make sure you get the correct make and model number as their are several different belts for this make of washer.
Let me know if you need anymore help ill be glad to help
Posted on Dec 04, 2007
  • 1314 Answers
SOURCE: washing machine smells like burning rubber!
sounds like you have a broken motor coupling while your down to the pump check for something jamming the pump here is the procedure First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 20, 2008
  • 1073 Answers
SOURCE: help
dissasemble the basket from the tub, did he not tell you how when he was there??????????
Posted on Jun 09, 2008
jsrock516
  • 5911 Answers
SOURCE: Spin Cycle on Wash Machine does not work
The problem is your lid switch. This is a common problem with this model washer, and a very simple & inexpensive problem to fix. Click on the following link for advice on how to replace:
http://www.fixya.com/support/r385198-replacing_lid_switch
You can find a replacment switch at searspartsdirect.com. Just type in your model number and look under the "Cabinet Parts" heading on the next page. I believe thats the heading the part is listed under. Sears has excellent part locator drawings to assist you in identifying the part. Once you have the part number identified, you can do some comparative shopping at other online websites too. Use the part number that Sears provides, however. A new switch usually runs about $25 to $35. In addition, make sure you check the lid strike. This is a small plastic piece on the lid that is used to activate the lid switch through a small slot. If the lid strike is broken off, it will give the same symptoms of a defective lid switch. I hope this information helps you. Please post back if you have any questions.
Posted on Aug 04, 2008
SOURCE: How to remove front panel of washing machine
there are two screws at bottom. unscrew. then lift up and out.
Posted on Nov 13, 2008
Maytag Atlantis Model 8551AWW washing machine...fills up with water...then starts the agitation cycle and will agitate for about 1 minute...then shuts off...after about five minutes the agitation cycle...
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Maytag Atlantis MAV8551 Top Load Washer
Agitator does not work
Your motor runs in forward and reverse...the spin is one way and the agitate is the other... that direction has failed. Replace the motor...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Performa agitates, but wont spin corectly.
heatman101
Jun 07, 2010 | Washing Machines
Washing machine GLWS1649ASO wont spin on spin cycle. motor and pulley turn, but belt doesn't move. Is it the belt?
no it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Oct 02, 2009 | Frigidaire GLWS1649A Top Load Washer
WONT AGITATE OR SPIN
check the belt that spins the tub, you will find it at the bottom of the machine, check if its intact.
plz do not forget to vote if i solved your problem
Sep 05, 2009 | Kenmore 24902 Top Load Washer
Maytag Top Load washer will spin but won't agitate
sounds like the coupler between the transmission and tub is broken or slipping
Aug 28, 2009 | Maytag LAT2600A Top Load Washer
My Maytag washer will agitate without clothes in it but will not agitate with clothes in.
The belt is not doing it's job. It could be that the belt is worn, if so a replacement can be bought from a Maytag dealer. It is also possible that the belt is just not under the proper tension. Maytag motors are mounted in a slide, and tension is applied by a spring. if the grease in the slide gets old and hard, the slide will stick making for a loose belt. To access, you'll need to remove part of the cabinet. Pop the top loose at the front, remove two screws at the top of the front panel, and release the clips at the bottom to remove the front panel. Free up the slide with some light motor oil and re-assemble.
Jul 12, 2009 | Maytag HAV3460AWW Top Load Washer
Maytag top load will not agitate or spin after belt replacement
Off balance arm was stuck. Removed control panel, checked all connections and and lid closed switch and it worked.
Nov 05, 2008 | Maytag LAT2300 Top Load Washer
Washing machine wont spin anymore
whirlpool made? check the coupler between motor and transmission. Open cabinet by unhooking 2 clips inside control panel and remove entire cabinet.
If its ge or maytag then check belt. Some maytag designs have the belt on bottom (below the cabinet). Other wise use paintscrapper to release 2 clips between top and front panels. front panel comes forward and unhooks from bottom.
Apr 24, 2008 | Washing Machines
Maytag washer
lean the washer back .......
Oct 07, 2007 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
112 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
