Question about Toshiba Sattelite A105-S2071 Notebook
The mysterious ticking motherboard
My laptop is the s2091 but it wont turn on at all
i have checked the power adapter and its good , i checked the fan and its good
the motherboard is making a faint ticking sound and i think ,that it whats causing the problem
now i took everything off the motherboard and it still makes that faint ticking sound (ie there is no hard drive, fan, processor, or any other drives on the board) and it still ticks
please if you know what the problem is, please help
  • icepanther Oct 22, 2007
    what does a capacitor look like
    There are none on this board at all
    Genius:
  • 1,601 Answers
A bad capacitor may be the problem.
Posted on Oct 22, 2007
  • 3 more comments
  • Thomas Christopher
    Thomas Christopher Oct 22, 2007
    they are small and looks like small cans. there are probably 25 to 50 of them on a board
    bad ca
    bad caps
    Thomas Christopher Nov 04, 2007
    Then it must be the hard drive controller. The question is how do you fix it. Unfortunately, controllers are integrated into the motherboard and the only way to fix it is to replace the motherboard.
    Sorry for the bad news.
    Thomas Christopher Nov 06, 2007
    Did this post work for you?
    Please post an answer so we can help you further.
    If it worked please rate this post as solved.
    Thanks,
Laptop wont power up
when you know for sure the adapter is charging ..and the battery is good..but no power seam to be present ..than the motherboard is gone .... or some contact is issued somewhere on the primary entry of the power..cause if any power would go through the motherboard..than at least the power led would be on ..or the fan should be heard .If there isn't any ..than it is something wrong with the motherboard or with some fuses on the main power source way ..but its a long guess...more than probably it is the motherboard..to blame ..
Nov 22, 2011 | Toshiba Satellite Pro L300 Notebook
Electricity spike computer wont start , AC adapter short circuit, computer computer crashed unable to power up is motherboard dead,is it possible to have computer checked out.
Some times the AC adapter and battery dies and saves your laptop motherboard.
Follow the following steps to check once again.
Remove the battery and the defective adapter and check if you can borrow a known good working adapter and see if your system works / turns on just by connecting the power adapter and turning it on (without the battery) if it works then repeat the check with the battery on.
If both the test works then your adapter is the only issue, get it replaced.
If both fails, you have to replace or service your motherboard.
Dec 09, 2010 | Toshiba (K000002020) Motherboard
Laptop shows thunderbolt to show its connected to power adaptor, but wont turn on at all. BTW, i replaced both the power cord and the battery, and it still wont turn on- no noise or fan, nothing at all....
The motherboard may be bad. Make sure the harddrive is securely connected. Reseat the RAM boards. Verify you are getting DC voltage out of the adapter tip by measuring it with a volt meter for around 19 Volts DC. If it's good, then check the power jack and verify you get a blue light around the jack when you plug the adapter. If you verified you're getting power successfully and still doesn't come on then the motherboard is bad.
Nov 01, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
First of all, i got a warning saying my battery needs to be replaced. As i await my new battery, i had been getting the blue screen of death very often. Then my computer shut down by itself and would not...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
As for laptop shutting down by itself, this could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 19, 2010 | Dell Vostro 1510 Laptop
Try to charge but wont. and wont turn on even pluged in
Aug 21, 2010 | Compaq Presario M2000 Notebook
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Push power button and it wont turn on on my
These tips may or may not help depending on the type, if any damage done to your system....
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Nov 07, 2009 | HP Compaq Presario V2000 Notebook
Cant get it to turn on/ panasonic CF-51 toughbook laptop.
Here are some troubleshooting hints, see if these will work for you. It is hard to knnow what to do in these situations because there is no way of telling what key combinations etc. were hit.
Oct 12, 2009 | Panasonic Toughbook CF-51 Notebook
Powerpack finr but laptop dead
how do you determine power is reaching motherboard ?if it is not turning on chk if u could hear any fan spinning if yes then ac adapter is working remove the battery and unplug the ac adapter and hold the power button for 10 sec and reconnect the ac adapter and turn on the laptop if not then remove the memory and turn on the laptop if u hear beeps then the mother board is fine
Aug 13, 2009 | Sony VAIO PCG-K35 Notebook
Toshiba Sattelite A105-S2071 Notebook Logo
680 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
