Question about Compaq Computers & Internet
Power on nothing shows on screen.Hooked external monitor results were the same
Nothing shows on screen when turned on.Tried hooking external monitor got same results
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
Processor or something like that, it's something inside the computer anyway, take it to a repair shop.
Posted on May 28, 2009
I have a Gateway M 1625 laptop. When I power it on the blue light is on for power and I can hear the fan turn on, but nothing shows up in the screen. Replaced the hard drive and still nothing. I hooked...
This indicates a motherboard issue, remove main battery and test, if no change! remove the ram memory one at a time and test each, if no result! it is time to get a professional in to assess.
Apr 17, 2012 | Gateway Computers & Internet
Black screen
If the notebook is not displaying anything when powering on, but is still powering on (indicated by the power LED lighting up) then you should consider hooking it up to an external display or monitor to test where the problem stems from.
If, when hooked up, nothing displays on the monitor it is a hardware issue with the either the Hard Drive, System board, or LCD.
If, when hooked up, the screen displays normally on the monitor, it is an LCD problem
If, when hooked up, the screen displays with artifacting, vertical lines, or discoloring, it is an issue with the system board/ Graphics card.
Mar 15, 2011 | HP Pavilion dv2000t Notebook
When i turn on my Acer Aspire 9300 the power comes on but will not boot up. I have even hooked up a external monitor that worked for about a week now NOTHING!!
if nothing showing on screen graphics card problem check the hard drive light is showing during boot up or it's a faulty hard drive to
Nov 16, 2010 | Acer Aspire 9300 Notebook
I just got a used syncmaster 203b monitor. I hooked it up and all I get is a black screen. I downloaded Driver whiz and hooked it up again. Still a black screen. Still get a black screen the blue light is...
Make sure that your computer unit is working. Sometimes we suspect that it is a monitor problem but usually, it is a frozen CPU set.
When you turn on the monitor, it should light the blue led and after a while, when it does not receive signal from the CPU, it will turn orange. If that is the case, the monitor is functioning well.
So what could be the problem?
Make sure that you hooked the monitor to the right VGA port. If you have an internal VGA port (built in with the motherboard) and you also have an external Video Card, you should hook it to the external VGA port and not the internal one since it is overridden by default.
Do you hear the "short beep" sound when you boot your PC? That signals a good video system. If you don't hear that beep sound (provided your PC's speakers are okay), you should open your CPU case and try to remove your memory modules (RAM). Clean the pins with an eraser and put it on.
Now, your computer should work fine and so with your monitor.
Aug 14, 2010 | Samsung SyncMaster 203B LCD Monitor
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
External monitor on Laptop not receiving a signal
When you start your computer, keep hitting the F8 key. you will get a menu that comes up.. Choose the VGA mode.. this will stop the computer from loading video drivers and will allow you to install the new monitor.
Give that a try.. Hope it helps... let me know
May 31, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
I hooked up this moniter turned on the power and nothimg black
My Dell monitor is showing odd splotches of colored bars.....turquoise bars and pink bars. What is causing this?
Apr 21, 2009 | Computers & Internet
Dell inspiron 1501 push power button no screen or sounds
Have you hooked it up to an external monitor? If you can see windows booting up on the external monitor then u may have a bad lcd screen or inverter or video card? Still lots of questions to ask.
Apr 11, 2009 | Dell Inspiron 1501 Notebook
Data Shows up only on External Monitor, not on Laptop Screen
If your system won't display anything w/o the external monitor. there's something wrong with the LCD's backlight. you may have to contact your laptop's manufacturer and check if this laptop is still under warranty. you may have to get the lcd replaced.
thanks.
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Monitor light blinks
have you tried hooking the monitor up to a known working motherboard video or video card in a motherboard? it sounds like you may not have the settings in the motherboard correct jump the cmos clear to reset the motherboard connect everything then turn on your monitor then turn on the computer and get back to me in this thread.
May 05, 2008 | Computers & Internet
Computers & Internet Logo
117 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
