Question about Actiontec (GT701) Modem
Cannot access D-Link router settings page
I cannot get to the settings page of my D-Link router because the IP address of the router is the same as the address of the Actiontec modem. When entering the http://192.168.01 address, I keep getting the modem settings page -- how do I access the router settings page?
  • Darryl Jaeger May 28, 2009
    When I unplug the modem, I can't access ANYTHING by enteringhttp://192.168.0.1 in my browser!
    Master:
  • 409 Answers
Unplug the modem
Posted on May 28, 2009
  • Cosma Papouis
    Cosma Papouis May 28, 2009
    in that case the router does not have the same IP address then
How can I configure my router so all of my laptops can connect to the internet? Also, do I need to make any changes to my laptops configuration?
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
3676-001.png 3676-002.png Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G Broadband Router
I need to get into my nat settings
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
I want ip
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on lan setting and note down ip address of router. if you want ip address from router then enable DHCP in router then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Oct 05, 2010 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
How to open d-524 router home page
How to access the router set up ?
You will need to check the IP address of the computer.
Do you have any computer connected to the rotuer ?
If not then you will need to check the IP address of that computer. The default gateway will be the IP address of your router.
Use that number to access the router page.
May 01, 2010 | D-Link AirPlus DI-524 Wireless Router
Router to Computer connection problem
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are still not able to access it then press RESET button for 10 seconds it is in back side of router .Then you can access it with above default ip.
Then you can DHCP there enable it then save settings and restart router.
Then set ip get automatic in your LAN proeperty set ip address get automatic.Then it get ip from router then it works.
Feb 02, 2010 | D-Link AirPlus DI-524 Wireless Router
When I type 192.168.0.1 into a browser I am taken to the www not the router. Default gateway has not been changed. I am attempting to access a D-Link DIR-655 Wireless Router.
this address is correct for ur router now u go to network connection u change ur ip address to ip automatic i think u can access to page configure dlink, if have problem email to me billy_nguyen57@yahoo.com
Jan 15, 2010 | D-Link DIR-655 Wireless Router
How can i setup my dlink 514 router?
Connect one of your computer to LAN port, access the configuration page of the router (IP 192.168.0.1) for the connection type choose dynamic IP address, clone the MAC address then apply the settings, Check the IP address under status (WAN section if you have the IP address it means that your connected)
Mar 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
Can´t I access the web-based configuration
Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Actiontec (GT701) Modem Logo
292 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
