Question about Homelite Curved Shaft Trimmer Bump Feed Replacement Line
Homelite curved shaft timmer line problem
My homelite 26cc curved shaft trimmer line never expands... it always just cuts off causing me to stop, take it off, put it back on. I line up the openings and tighten the nut but it never automatically extends the line... ideas?
  • 2 more comments
  • dgrab599 May 29, 2009
    if I take a brand new spool, screw it on, align the openings and use it, it doesn't extend the line and it just snaps off. I then need to unscrew it all and extend it again and then it just cuts off again..
  • Jim Parker
    Jim Parker May 11, 2010
    Is it a bump and feed trimmer?
    Jim
  • Dwain Pippen May 11, 2010
    Be sure you have the line wound the opposite way the head turns.
  • Samuel Charles Spriggs May 11, 2010
    Hate to give you bad news, but weed whackers were invented by a committee of sadists.
    You can spend the rest of your upright life trying to get one to properly function again once it fails -- my advice is to give your current machine to a very good handyman/woman and buy a new one.
It sounds like its a bump feed which they usually are, try turning on the machine and bump the head off the ground. If this fails to work try rewinding the line on tightly and neatly with no parts of the line crossing over as this could knot it. Quick tip most heads have a arrow pointing the direction to wind the line.
Let me know if that works.
Posted on Jan 09, 2010
  • 1,040 Answers
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
Posted on May 29, 2009
  • Jim Parker
    Jim Parker Jun 03, 2009
    Did this solve your problem?
    Jim
My 26cc homelite straight shaft weedeater keeps
If the guard isn't in place and cutting the string to length as it's running, it will keep feeding line out.
Sep 23, 2014 | Garden
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Jul 12, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Need a manual for Homelite weed eater, UT 20760. It can be in PDF format. Forward to guitar0589@comcast.net. Thanks
You can download the trimmer PDF for free here - http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_trimmer_product_list.html
Jun 28, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
How do i adjust the homelite carburetor , the trimmer starts and continue working but has no power to cut the grass
if you have had this trimmer for a wile you might check the little muffler to see if it is cloged up with carbon i had on and adjusted the thing till i was blue in the face and pulled the sreen of the muffler cleaned it now it runs great
Jan 29, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Homelite Curved Shaft Trimmer Bump Feed Replacement Line Logo
1,006 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
