Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Rx not glowing
Hi, my name is mrinal and i work on hughes modem hn7700. my receive led is not glowing what can be the problem
  • 256 Answers
The HN7700 apears to be the hughes satelite modem. Make sure the dish is still aimed properly. Strong winds can move it off line. Make sure the cable is attached to the LNB unit. Best way to do that, is to remove and re-attach it. My guess is the dish alignment os out. If this is not a satelite modem then you can ignor this solution.
Posted on May 28, 2009
My company has not used our wireless connection in a long time and has forgot the passphrase to get into out hughes HN7700S Routor. is there a default one that we could use
Hi.
I checked, and there actually is a default one for you.
Unlike alot of other brands of satellite type modems, the Hughes corporation, being a large Government contractor decided to put a default login-password into all their machines.
Now, if your company has changed the password on it more than a couple of times, then this might not work.
First, you will need to open your browser, and in the address bar type in 192.168.1.1
This should access the router itself.
Next it will ask for a login and password.
Type in ADMIN as your login name, and leave either type in ADMIN again for the password blank.
Hughes says both of these ways should work, but you need to try them for yourself to see which one it is.
After you access the modem, then you can adjust the settings, change the password, and anything else that you wish to modify.
Just don't forget to wite eveything down that you change, otherwise you may make it where noone can access it at all.
I hope this helps you out, and have a good day!
Apr 30, 2011 | Computers & Internet
I can not make my D Link DIR-615 work with Hughes HN9000 modem. The D Link is located at the PC and Hughes modem location so I can wire 1 PC but need the laptop to connect wireless. I tried both an...
If you connect Modem to your laptop, can you go online?
If you are able to go online like that then log onto www.hnetworking.com and we can take the remote access of your computer and try help you out.
Feb 28, 2011 | D-Link DIR-615 Wireless Router
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Default IP Adress of the modem Hughes HN7000S
The Hughes addresses are 66.82.4.8 and 66.82.4.12.
Mar 06, 2008 | Computers & Internet
Adsl modem not working
First you must have a steady led light on the on Power, Act and Lan, the Sync led will flash until the modem connects to the DSL line. If you are not running a router but only a modem, you will need to create a PPPOE network connection on the computer. If you are using a router with the DSL modem you will need to create the PPPOE connection only on the router. I had recently a problem with the DSL service to my home. My modem showed DSL connected but could not connect the PPPOE connection, the telephone company had to reset the circuit that I am on which fixed the problem. BPCS
Dec 06, 2007 | Acer Altos G500 Server
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
71 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
