Question about Canon ImageClass MF5770 Laser Copier Printer Fax Scanner Network
Alarm light is on it says( check paper size) this is a canon mf57700
  • KansasEskimo Apr 17, 2008
    I am having the same problem with the same printer.
    I just want to clear the memory. But the 'reset' button does not help. Nor does the 'clear' button. I have unplugged the printer several times, and still the memory is holding on to the 'oversized' spreadsheet, which gives me the same message as you were getting last fall.
    Did you find a solution?
    DTP
  • newexpfin200 Mar 18, 2009
    Canon Imageclass MF5770 Printer. the alarm light is on, the message is showing: "change paper size, cassette:A4" "check paper size".
    also after i unpluged the power and make a single print, the printer keep continue to print out the same page. i need help. newexpfin2007@yahoo.com
I had this problem also. I was unable to clear the paper size error. Finally I loaded the papersize that the printer was wanting (A4 in my case) and let it print. Once the print job finished it was back to working normal.
Posted on Jul 29, 2008
Canon LBP 3300 printer A4 Paper is already loaded in Cassatt 1 but "Load custom paper in manual feed slot" massage shown when given print comment
these instructions r for win xp
go to printers and faxes select canon lbp3300, right click and select printing preferences set out put paper size as A4.
Apr 16, 2011 | Canon LASER SHOT LBP 3300 Printer
How to print A5 paper incannon 3300?
Go to printer and faxes, right click, printer preferances, page setup ,size , select A5 then paper source select casste 1. then click ok. Feed the paper through cassete 1. Print ready
Apr 03, 2011 | Canon LASER SHOT LBP 3300 Printer
Light under memory/alarm is flashing red. Window
if the error is change paper size also, under printer properties set the paper size i.e. A4, by default its ltr and these can cause problems.After that turn off and on.
Hope that helps.
If not, send more detailed description.
Aug 27, 2010 | Canon imageCLASS D320 Digital Copier
I am getting the alarm "check paper size" and then it jams.
set the select paper size of user data fax printer setup to the size of paper loaded in the paper cassette.
Mar 15, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Incorrect paper size so fax was received in
That suggests a sensor is jammed or damaged... sorry I know no more.
Nov 04, 2017 | Canon FAXPHONE L170 Plain Paper Laser
Red alarm keep coming to my (Canon imageCLASS MF5770 Multifunction Printer) and display message: CHECK PAPER SIZE AND CHANGE PAPER SIZE CASSETTEL LTR. please guid me through steps. thanks!!
Chances are the paper size in the cassette doesn't match the paper size (or alignment) that you've tried to print. Verify the paper and alignment of the paper match what you're trying to print, and that the paper guides in the cassette are locked into position for the size and alignment you're working with.
Aug 05, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Canon MF5700 Series all in one printer
Throw it in the trash. It's a piece of shi*. I'm sick of mine.
Jun 25, 2008 | Canon ImageClass MF5770 Laser Copier...
What is the remedy for copier's red alarm button blinking & fax not working?
Do you mean the "Out of paper" alarm? Check that all paper trays have paper. The by-pass tray should be prperly set to receiv "Legal" size paper and have that size paper in that tray.
Mar 30, 2008 | Canon LaserClass LC 8500 Plain Paper Fax
Alarm
Have you checked to make sure your paper guides in the paper tray are set correctly? If so then you might need to go into the printer menu and see what the paper size is selected for on that paticular tray!!
Dec 04, 2007 | Canon imageCLASS MF8170C All-In-One Laser...
686 people viewed this question
old marine
old marine
