Question about Maytag Dryers
HiMy name is Ray and i would like to increase the drying time on a maytag commercial dyer model lde19cs
Hi My name is Ray and i have maytag commercial electric dryer model LDE19CS but the problem is i need to increase the time cycle,from 48 to 60 minutes. How i do that. I need manual I have a maytag commercial dryer lde19cs and i would like to know how to increase the drying time on this unit,i don't have the manual and would either need how to do this or where i can get the manual for this dryer,thank you
I just got off the phone with Maytag Commercial Laundry customer service, because i needed to know how to adjust the run times on this dryer model. here is what i learned:
there are slots in the timing cam into which fit a white pin for adjusting the run time. the letter settings on the cam are set at 12 minutes apart:
E = 12 minutes
D = 24 minutes
C = 36 minutes
B = 48 minutes
A = 60 minutes
if your dryer is running 48 minutes, that pin is likely in the 'B' slot. remove the pin. the built-in stop at the 'A' position is for 60 minutes.
Posted on Jul 02, 2009
I have a Maytag Neptune electric dryer model # MDE9700AYW and I have a fault code " FE " & the dyer doesn't dry the clothes. What is my problem
Maytag Dryer and FE code means power source "Frequency Error".
Invalid power... you will need a electrican to come out the power is not wired up right.
I would replace the wall receptacle before buying any dryer parts
Hope this helps (remember to rate and comment this answer).
Jul 01, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
My dyer is model # MDE7400AYW out of the blue the cycle more dry to less dry wont work & the Intelli sensore quit working but thats it the rest works I cant find the troubleguide to try and fix this...
Hi Molly,
Here is a link to your owners manual (below)
A couple of things to note you may know them already but here goes. The intelli sense will not work with Time Dry. Inside your dryer are two metal rods about the size of a pencil, if they get coated with residue from like dryer sheets the sensing will not work, you can take a rag with alcohol and wipe them clean.
If all these things do not work you may have a failure of the intelli sense board.
Let me know if I can help further.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202206688.pdf
Apr 21, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Short drying time
probably will have to replace timer motor with one that has a longer run time.
Jul 07, 2009 | Maytag MDG16CS Gas Commercial Dryer
You either change the timer motor or you change the
Timing cams. Contact Lobright manufacturing in Queens village new york 888 - 829 - 0009
I do not know if my friend Bob Pinkney is still there but ask for him and tell him JW said hi. Ask him to send you a catalog. In it you will find all sorts of laundry matt stuff plus those cams and motors.
May 11, 2009 | Dryers
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag dryer model LDE8410acw
Hi james,
How old is the dryer?
Sounds like a bad element!
Age determines if it's worth the investment !
Sep 18, 2008 | Maytag MDG9606 Dryer
Maytag coin op dryer timer programming for mde-16cs
The maximum run time on this machine's timer is 54 min. There is an adjustable peg on the white plastic index wheel which you can adjust anywhere from 30 to 54 min. For example peg in position E is 30min, D is 36min, C is 42min, B is 48min or for 54 min you have to remove the adjustable peg completely, but don't lose it in case you want to change the time in the future. If it is already in the Max "A" position and shuting off early you might have to change your torsion return spring. Hope this helps
Jan 06, 2008 | Maytag MDE16CS Electric Dryer
Dryers Logo
378 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
