Thanks for your help,was wondering what the difference in the modem/adapter/and the router functions are? I'm not computer savy. they all sound to me to do the same thing. Do i need 1 of each?Thanks
1, A modem connects your devive to a communication line (phone line, cable line, broadband).
2, A router directs your traffic to the correct location on the correct network.
3, An access point allows you to connect to a network wirelessly.
4, A hub allows you to connect several pc's to form a network.
5, A firewall keeps the bad guys out
You need one of each. Typically you buy one box that has everything in it. It connects to the internet, firewalls that connection, allows you to connect 4 pc's (and more via the wireless) and routes that traffic to/from the internet as required. (all for under £100 - very impressive :) )
Hi there.
You can buy just 1 device nowadays a wireless modem router, this will connect directly to the cable or telephone socket and give wireless access almost straight away.
The idea of plug link adapters is that you plug one of the adapters into a standard
electrical outlet near your broadband router, and connect it to the
router with an included Ethernet cable. Next, you plug an identical
adapter into an electrical outlet in another place in the home or
office, and connect it to another computer with a second included
cable. No software, no setup procedures, no drivers. How sweet.
For all intents and purposes, it's a wired home network, except it
has a couple of these small black devices in between. And the dog can't
chew the wires.
The building's electrical lines do the rest — they carry the
computers' high-frequency data on top of the low-frequency waves on the
electrical transmission lines, and the two can cohabit quite happily
without interference.
And you can buy individual powerline adapters as you need them, up to 16 of them before the speed begins to degrade.
What's more important is that this system works far better than a
home wireless (WiFi) network, which often can't reach all the corners
of the house or office — especially if there's a microwave oven working
nearby — and is much slower.
Regards
WOW! thanks, that helps alot. and clearly . Okey I was also sent 2 plug link adapters, what are they suppose to do. and do i need them.
I have an 2wire modem on the main desktop pc . a wireless adaptor on a second desktop pc. and a laptop to figure out.Ive been sent all this stuff from AT&T. but i'm not sure what or if I need it or do i need more. BLUH!!!!
Thanks
