When I just installed the 2GB SD card I received a message on the view screen that states"Memory Card is Full". What do I do to correct this problem. I read the liiterature that came with the camera and I did not see anything that stated I could not install a 2GB SD card in this camera. Do I need to return the 2GB SD card and continue to only use a 1GB card or is there something that you can have me download to enable me to use this 2GB SD Card?
Please advise - your assitance would be greatly appreciated.
Thanks, Paul Brannigan
Hi there.
Make sure that the write protect is off.
Face the card towards you, look for a small white tab on
the left hand side of the card, to unlock it push the tab down, it will
be at the side of the card like this .
Also use the camera's menu to format the card for use with the camera.
Please post back if you need any additional advice.
Good luck and thanks for choosing FixYa!!
After having the same trouble, I installed a 1 gb card and it worked just fine. It appears the Kodak C330 won't recognize a 2 gb car.
