Question about Hoover 24 in. HD97E Free-standing Dishwasher
Control Lights off - Candy CDI 2012
All the programme panel lights are off on my Candy CDI 2012 integrated dishwasher. The Salt light is on, so I know it's getting power, and I have disconnected and reconnected the inlet and outlet pipes just to be sure there is no pressure build up. Any ideas? control lights out salt light on not completing. water in bottom.
  • 641 Answers
SOURCE: dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
Posted on Aug 18, 2007
  • 108 Answers
SOURCE: dihwasher not working
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the pump.
Sure enough there was.
1. Unplug your dishwaser at the wall.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Don't forget to rate me!
fyi
The third time about 1 year later this occured again and even hotpoint gave up as they could not fix the machine. (after multiple visits). I think that the two flashing lights are were a red herring and the dishwasher had a separate intermitten fault. Hotpoint replaced the unit for a mimum charge. Callout + 40
Posted on Feb 27, 2008
SOURCE: diplomat slim dishwasher ADP8352
you have water in the base and low insulation 3 things either leak or to much foaming get weaker tablets or back flow from sink, when it drys out it will work
Posted on Apr 26, 2008
  • 1462 Answers
SOURCE: salt for DDW1805 Danby
yes it is - salt is used to regenerate the water softener in the dishwasher
Posted on Jul 12, 2008
  • 4 Answers
SOURCE: Leak from salt reservoir on the DT999
Replace water softner seals (Hoover spares reference: 91941698) as stated previously. Harraps were doing them for £6 each. The softner is accessed by removing the R/H panel and unscrewing the air break ring nut from inside the machine. They are not a standard size so oem o rings are recommended.
Posted on Sep 08, 2009
I have a Smeg DD612 dishwasher... is it economic to repair it?
If repairs will cost 50% of the cost of a new one, consider replacement.
Jan 24, 2017 | Smeg Dishwashers
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Aquarius DWF32 and dealing with water softner
Good idea to check levels yourself, but wear rubber gloves as dishwasher salt will leave your hands very sore, simply remove cover from salt tank, using a wooden spoon handle or similar check salt level and refill if required, replace tank lid, never wait for warning lights, they may never come on, good luck.
Feb 18, 2013 | Hotpoint Aquarius Washing Machine Front...
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Oct 11, 2010 | Candy Dishwashers
Candy dishwasher 2 program lights keep flashing after program starts then stopas and flashing starts
My candy dishwasher Model No CDI 3015-S retains water in the bottom of the machine at the end of the program. I have checked the filter which is clear so do not know what else to do to clear the problem. Anyone faced this problem or know what might be the cause?
Jan 18, 2010 | Candy 17 in. CS455 Built-in Dishwasher
My candy dishwasher CSD68-80 rinses but then the rinse and wash light come on together. Nothing happens after that.
I checked all filters which were ok. Put bleach into the place for salt. I know this was a risk. Switched it off overnight and it worked perfectly the next time I used it.
Aug 01, 2009 | Candy Dishwashers
Leak from a De Dietrich Integrated Dishwasher has caused 3 red lights on the left of the Control Panel to flash and also a Blue Light on the right hand side of the Control Panel to flash. On resetting...
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Oct 05, 2008 | De Dietrich Dishwashers
HELP WITH NON FUNCTIONING DISHWASHER
similar problems here, repair man says its fine but the salt light was on so i added salt and works ok now. Some dishwashers don't function properly without the salt and rinse aid, even though you're pills may have then included, you still have to add them seperately, dumb but necessary at times.
Feb 27, 2008 | Dishwashers
Hoover 24 in. HD97E Free-standing Dishwasher Logo
387 people viewed this question
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
