Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Cuts lawn uneven, one side shorter than other
I just put new blades on the riding mower, Craftsman 42" Briggs & Stratten. Still I get one side cutting shorter than the other. Is there an
adjustment that can be made to fix that situation?
Thank you
  • 376 Answers
Was it cutting uneven before you changed blades? If so, you may not have gotten the blade on the shaft correctly. There is an adjustment in the center of the deck hanger on each side. You can turn the 9/16 nut up or down on each side to level it out.
Posted on May 28, 2009
  • 1 more comment
  • gene_moore70
    gene_moore70 May 07, 2012
    check the tire pressure to make sure they are the same on both sides.
  • Richard Wilkie Oct 18, 2014
    theres an ajustment on the 1 side (right side and its a 3/4
    i mean left side
Cuts lawn uneven
Need to adjust mower deck side to side and front to back.
May 30, 2012 | Craftsman 21 Hp 42" Lawn Tractor Riding...
My tractor cuts uneven when i am cutting my yard
Check your blades common problem with uneven cut is a bent blade. Next find a level spot like a padio and take a torpedo level place it on the front center side to side not front to rear. On one side or the other you should see a J(jay) bolt with a nut tighten to raise losen to lower.
Terry
Aug 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
42 inch mower cuts uneven, what is the problem?
Several things here could be the problem. Check to see if mower deck is level, measure distance on both side on a level surface. Check tire's for low air. If you've replace the mandrel's lately, some have a left & right side & if not put back together properly this will cause uneven cutting
Aug 03, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
What would cause the deck to cut shorter on one
One of the blades was probably bent upwards when you hit the log. These blades are very difficult to straighten without machine shop tools -- blade will probably need replacing.
Charlie
Sep 27, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
2003 DLT3000 Craftsman riding mower. Air in tires correct, deck level front/back & side/side, new blades.. Still cuts uneven. Does this deck flex when cutting tall grass & how do I fix this...
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
Aug 26, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,410 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
