Question about Canon IXUS 860 IS Digital Camera
Image i have lots of pictures in my card but it cames as no image
  • 10,515 Answers
Try to download the pics to the notebook/desktop. In case you are getting the same issue,It's corrupted memory card.
Call a tech if he could retrieve pics from corrupted card.
Thanks for using "Fixya".
Posted on May 28, 2009
Lost photo's after recharged camera
If the pictures were on the card and you have not shot more pictures or video since then with the same card in the camera, their probably all still there.
Put the card in a reader, and scan it with image recovery software. The process takes a lot of time, but will give you all the pictures that are currently on the card, even if you accidentally erased them.
Deleting pictures alters the way their identified, but does not remove them from the card. When you recover them, the program looks for images that are no longer identified normally, and puts them in another file with new identification so your computer can see them.
When you add pictures to a card it overwrites the old picture files, and that permanently destroys the old files. Formatting the card removes all the picture information on the card permanently.
Oct 13, 2013 | Nikon COOLPIX S4300
I lost my pics on file on the camera after i hit "format" "yes" help!
If the pictures were on a memory card and you haven't done anything to the card since formatting it, you should be able to recover at least some of the pictures. Do a Google search for "data recovery software" and select a program suitable for your computer and operating system. Put the card into a card reader attached to your computer and run the program.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Sep 28, 2012 | Video Cameras
Cannot see exported images in 3d view .
you might have lower video card specs, or the version is not compatible with os
Jul 05, 2012 | 3M Chief Architect Home Designer Suite 8.0...
I can only take at least 15 shots in my Cannon Powershot A590 IS, pls. help me how to adjust for me to take pictures atleast hundreds of shots.
Your camera has limited storage using internal memory and probably came with a 32 MB memory card. An SD card of even 1 GB (tiny by today's standards) will hold about 100x as many picture as your internal memory.
Buy a larger memory card. These don't cost much and a 1 GB card can hold a LOT of pictures. After 1 GB, there are differences in the memory cards and the higher capacity card might not work in your camera.
If you want to increase the number of pictures you can store either with the current card or using internal memory, then you have a couple of other options. 1) change the picture size to "small" and 2) set the compression to "normal" to achieve the maximum number of images for your memory. Warning: small and normal might give pictures that are too low of resolution for what you want.
Jan 27, 2011 | Canon Accessory Outfit Case Flash Memory...
Adjusting Pictures Resolution
you use the function button while in camera mode and scroll to the image size then turn the function dial to change it. you should consider taking your photos on the higest resolution, however, because SD cards are very cheap and you can get 8GB cards for under $40. Your camera came with a 32MB card which is tiny--you should throw it away. 8GB will store hundreds of 9 megapixel photos--i recommend having at least two SD cards. i hope this helps.
Mar 12, 2009 | Canon PowerShot SX110 IS Digital Camera
Didnt realise I furst had to format the memory card for my new Nikon D60. Took lots of photos at the weekend but when I took out the card to download the images there was nothing on it. However I can...
in some cases we have found that if there is a virus on the card and if you try to read it directly on a computer having anti virus activated, the computer shows card as a blank. As the camera software is not effected by the window based virus, it can read the data. Try connecting the camera to the computer via USB. As the widows xp or higher versions do not require drivers or the camera software to be loaded to recognise the camera you can directly transfer the data from your card.
Jul 23, 2008 | Nikon Cameras
My Nokia Changjiang N95
spider man box format the mobile
Jun 18, 2008 | Nokia N95 Cellular Phone
JUST USED MY CANON 950IS FOR THE FIRST TIME USING A SANDISK ULTRA II SDHC 4GB CARD. DOWNLOADED FIRST PICTURES ONTO LAPTOP USING THE MICROMATE WHICH CAME WITH MEMORY CARD. WHEN I'VE PUT THE CARD BACK IN...
Sounds like a card problem. Did you format the card in the camera when you first got it? If not, recommend formatting it using the camera. Look for the format option in the camera's menus. Note that this will also erase all images from the card, so make sure all pictures have been first downloaded to your computer.
Jun 02, 2008 | Canon Cameras
Unidentified Images.
I would try formating the card using the camera (menu - setup - format) - THIS WILL ERASE ALL THE PICTURES YOU CURRENTLY HAVE ON YOUR CARD, so before you do this you may want to get a memory card reader and transfer the pictures (click and drag) to your computer. As to using the 4GB card...you will have to check with canon if a card that size if compatable. Not all cameras work with SD cards larger than 2GB.
Jan 04, 2008 | Canon PowerShot SD1000 Digital Camera
No images
Look in Explorer at the .jpg files on your card to make sure they have information in each file. Next, make sure your software is set to view .jpg files,i.e. Faststone Image viewer (download.com) can be set for virtually any image format. If you viewed the images on the lcd monitor they were on the card at that time. Make sure you haven't somehow protected those image files or have accidentally reformatted it.
Aug 28, 2006 | Nikon D70s Digital Camera
Canon IXUS 860 IS Digital Camera Logo
46 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
