Question about HP Compaq Evo n620c Notebook
I have trouble of my desplay, power work ok but can not display any thing
Sir i have hp520 note book. screen display not work if i connect moniter then display ok . can you help me? My problem is, the machine just goes off, but the power is coming. No display even when I connect it to a monitor
  • 489 Answers
Hey. there is a inverter in LCD that makes view brightly shinely so you can see everything on LCD. anyway. if the inverter breaks down you get black screen. even inverter is working you get blanc screen you need to check LCD DATA CABLE that it not possible to reach it for you. i advise you to get the Service if you have warranty
have a good day.
pls rate this.
Posted on May 28, 2009
  • meteshadow May 28, 2009
    hey there. there is a inverter in lcd that makes whithe bright shinely. anyway if it break down you can get black screen. look carefully something on LCD that you cant see clearly or there is nothing. if there is nothing it looks like your lcd break down. otherwive your inverter down. need to go to the Service
Hello sir i have a broblm in my samsung synicmastr 19" blak, when i switch on the moniter, the moniter is with in 2 or 3 second automitically off the display light but moniter is still on and display...
this problem can occur cause of two cases 1 problem with LCD panel (replacement can solve) 2 power failure in side moniter (repairing moniter can solve)
thanx PLZ vote
Feb 22, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
Power supply done but display is not
Symptom : No Image on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power connected properly ?
Action : Check the power cord connection and supply.
Checklist 2 : Can you see "No Connection. Check Signal Cable" on the screen ?
Action : Check the signal cable connection.
Checklist 3 : If the power is on, reboot the computer to see the initial screen ( the login screen), which can be seen.
Action : * If the initial screen (the login screen appears, boot the computer in the applicable mode (the safe mode for Windows 98/95) and then change the frequency of the video card.
* Note : If the initial screen ( the login screen) does not appear, contact a service center or your dealer.
Sympton : I cannot see the ON Screen Display.
Checklist : Have you locked the On Screen Display (OSD) Menu to prevent changes ?
Action : Unlock the OSD by pressing the MENU button for atleast 10 seconds.
Hope this helps.
Have a good day.
Dec 08, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
HELLO, I have a Toshiba laptop note book computer, Satellite A15-S127...INTEL CELERON 2.0 GHZ With USB 1.1 made in 2003 and a slot for PCMCIA Cardbus... I already have a second moniter (externaly)...
Suggest you buy and install a USB 2.0 adapter card.
Example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Sep 06, 2009 | Computers & Internet
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Philips 150B4 White Screen with the word Aging...
I have a philips 19 lcd. the damn thing just display a white screen with the word aging in red in the certer. it goes off after a while, turn black a while then comes back again, with the white screen. keeps doing it over and over.
anybody have any idea?
i tried caps, but all the caps look good.
to be noted i didnt change all.
Apr 20, 2008 | Computers & Internet
Monitor LG FLATRON E700SH
Sir,
I hve read all above statement which shown as above. but in my case monitor take time to ON and display the screen, its take at least 45 minutes to start up and display the window screen. So please to send me solution about my Query.
Thank's
Feb 21, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Hp notebook t2050 display problem in battary use.
you need to change the setting in your power manager, as your laptop is trying to conserve power, you can change the settings, however you may affect your battery life.
Sep 19, 2007 | HP Pavilion dv4000 Notebook
Display problem Imate jasjam pocket PC
There are many possibilities.
This forum has got a lot of info on HTC phones and Jasjam is made by HTC.
http://forum.xda-developers.com/showthread.php?t=303872
Hope it helps and sorry I can not be more specific as the issue is hardware related but to pinpoint the fault I need to have the phone on my workbench .
Aug 17, 2007 | i-mate JAM Pocket PC
HP Compaq Evo n620c Notebook Logo
111 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
