Question about Poulan Garden
Replacing the Drive Belt on a Poulan Riding Mower
I am attempting to replace the drive belt on my Poulan Riding Mower. The model number is PP1844B. It has a Kohler motor. My problem is how do I remove the electronic clutch to get to the belt. It is connected to the main belt pulley? When I place my socket on the nut the main pully turns freely with the clutch assembly. How do I remove both peices so that I can change the belt?
  • 376 Answers
Without an impact, it's will be more difficult. The only way to get back-up on the bolt is to remove the screen over the flywheel on top and put a socket on the flywheel nut
Posted on May 28, 2009
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
Starts but wont drive
Sounds like your drive belt came off the pulley. Look at the bottom of the engine. If you see a loose or broken belt, that's the problem.
Aug 29, 2016 | Poulan Garden
How to adjust tighten drive belt on Poulan riding mower with 18 hp b&s motor 42 deck
Probably needs a new belt.You can buy a belt dressing and spray the belt once in a while. Its a special sticky spray for belts that slip.
That will keep you going for a little while.
Apr 11, 2015 | Poulan Garden
WHAT SIZE DRIVE BELT I NEED FO 30" RIDING LAW MOWER ? MODEL NO P01230lt SERAL NO.011310A001123 model no PO12530lt 12.5 HP
We do not have any info on this site
Just a chat room
Take you info to a small equipment
dealer/repair shop & they can look it up
for you
Jul 06, 2014 | Poulan Pro Lawn Tractor 2006 and Newer...
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Do you have a drive belt diagram for an AYP ride on mower model number GS14536H?
normally replacing malfunctions requires knwoning what is preior wjrog whether is mechcanical alos electrical also instrumental thereafrter attempting to fix by finding every parts that needs replacement.
May 13, 2013 | Garden
I need to replace the drive belt on my lawn tractor.
Things You'll Need
  • Wrench set
Show MoreInstructions
    • 1Find out the driver belt's part number. This can be found in your lawn mower's owner manual.
    • 2Find a store that sells Craftsman lawnmower parts and see if it has your specific belt in stock.
    • Sponsored Links
    • 3Clean out the underside of your mower's deck, making sure there are no leftover pieces from your old belt still stuck inside.
    • 4Find your mower's tensioner, which keeps the pulleys in place, and loosen it (this usually involves loosening a single bolt). Then slide the pulleys closer together so that you can fit the belt over them more easily.
    • 5Arrange the driver belt over the pulleys (you should refer to your user manual for the exact configuration of the belt over the pulleys, since this will vary depending on the specific model of your lawn mower).
    • 6Tighten the tensioner back up, leaving only about a finger's width left of play in the belt.
Sponsored Links
Read more: How to Replace a Craftsman Lawn Mower Drive Belt ' eHow.com http://www.ehow.com/how_4826688_craftsman-lawn-mower-drive-belt.html#ixzz27K3g01yM
Sep 23, 2012 | Garden
Belt diagram craftsman 917 2733100
Assuming your model number is 917.273100, go to ... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number, hit search then scroll down to Ground Drive
Jul 27, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Trying to find the belt size for a poulan riding mower
yuo need the serial number model number etc and find a websiter who sells em or go to somwere that repairs mowers and have them order one
Feb 26, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
741 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
