Question about Whirlpool GD5SHAX Side by Side Refrigerator
Replacement water filter cartridge
After installing a replacement water filter cartridge, the indicator light flashes at 1% or 2% instead of reverting to 99%. This happens every time I replace the filter.
  • Tabukee May 29, 2009
    Thanks for the info, but I was probably not helping by being vague about the model number which I didn't know at the time. It is S20DRSB33-A/G.
    I would be grateful for a fresh solution based on this info.
  • Tabukee Jun 03, 2009
    Yes, thanks, the Whirlpool number is by the crisper drawer. However, it is the number I originally quoted (S20D RSB33-A/G), and which you say is for a vacuum cleaner or washing machine.
    The replacement filter number quoted on whirlpool parts.co.uk is 481281729632
  • Whirlpool Master
  • 4,655 Answers
Try disconnecting the refrigerator for 5 minutes. This should reset the control board. This should cause the board to flash 3 times red and then change to green. Now if I am off base with you I can send you the repair manual. Thanks, Sea Breeze
Posted on May 29, 2009
  • John Tripp
    John Tripp May 29, 2009
    That new number comes up as a vacuum cleaner and washing machine. Look at photo below and see if you an see a whirlpool number in these locations. Its OK everyone has this problem. heck I can see but my refrigerator is so hard to see I had to call Ray Charles!
    http://servicepartstec.blogspot.com/
  • John Tripp
    John Tripp Jun 03, 2009
    Thank you for responding. I get this a lot numbers from the UK customers from the UK. I like everyone,least I give them a chance to be liked. Sometimes it is difficult to respond to UK customers as GE UK and Whirlpool UK will not respond to my request on manuals. The want to do the in home service. Sorry if I misunderstand your reply. But I am still here to help you. UK home voltage is vols ac Thank You, Sea Breeze
How do you reset the filter reminder warning light?
Filter Replacement
Filter Replacement Indicator:
Your Defender® is equipped with a Filter Replacement Indicator located on the front
panel. Anytime this red indicator flashes, it is recommended that you call your authorized
FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops
flashing and remains solidly illuminated, it is recommended that you change your filter. To
receive full benefit from your Defender® and to extend your warranty, it is strongly
recommended that you follow the filter replacement schedule suggested above. Under higher
pollution levels, your filters will need to be replaced more frequently.
The Filter Replacement Indicator is operated by filter time in use and is controlled by an
onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter
Replacement Indicator will begin to flash. It will continue to flash until the you reach 12
months of time in use, at which time the Filter Replacement Indicator will stop flashing
and remain solidly illuminated.
After replacement of your Medi-Filter® Cartridge, you must reset the Filter
Replacement Indicator's timer. When the timer has been properly reset, the Filter
Replacement Indicator will turn off.
Resetting the Filter Replacement Indicator Timer:
After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the
Filter Replacement Indicator's timer can be reset by performing the following sequence of
steps:
1 Plug unit into outlet.
2 Press power On/Off switch to the On ("I") position.
3 Allow unit to start running at low speed.
4 PRESS and HOLD both the Up and Down arrow buttons until the Filter
Replacement Indicator starts to blink.
5 Release both the Up and Down arrow buttons.
6 While the Filter Replacement Indicator is still flashing*, again PRESS and
HOLD both the Up and Down arrow buttons until the Filter Replacement
Indicator turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will
turn off and not flash again for 11 months. If the Filter Replacement Indicator remains
on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when
the buttons are pressed the second time. The Filter Replacement Indicator will continue
to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Note: Under higher pollution levels, your filters will need to be replaced more frequently.
Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call
1-440-846-7800 for the Distributor nearest you.
http://www.filterqueen.com/pdf/defender.pdf
Mar 02, 2011 | Filter Queen Defender Air Purifier
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Nov 19, 2010 | Filter Queen Defender Air Purifier
Replace air filter warning light to reset?
Sep 30, 2010 | Filter Queen Defender Air Purifier
Blinking red light above the lowest setting on filter queen defender air purifier.
Sep 23, 2010 | Filter Queen Defender Air Purifier
How do you reset the red light on the defender when you put in a new filter? My light has never went out and I think it is supose to .
It won't go out by itself.
Sep 16, 2010 | Filter Queen Defender Air Purifier
No more steam. Want advice on disassembly.
There is info on the FAQs from Air-o-Swiss:
http://www.airoswiss.net/service/faq.aspx#35
Q: No mist / unit is not working / empty indicator keeps flashing
A: Fill up the water tank. Check if water is flowing through the demineralization cartridge (attached to the water tank cap). If the water tank is full but there is only little water in the base it indicates that the water is now flowing through the demineralization cartridge.
  • Wait for 15 minutes to allow the mist to come out of the unit.
  • If the unit is not working and the empty light is not flashing you might have set the desired humidity too low and the current humidity level in the room is higher. That is why the unit switches off automatically.
  • If the empty indicator continues flashing and the tank is full, water is not flowing through the cartridge. Exchange the cartridge or the granules in the cartridge after 2-3 months, in areas with hard water exchange the cartridge after 1 -2 months. However, the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit does not reach its full performance.
If the granules are new, see the following instructions:
  • Make sure the cartridge and/or granules were soaked for 24 hours, water takes longer to filter through dry granules in cartridge and into the base. Next, remove 2 tablespoons of granules from the cartridge, and throw them away. Too many granules in the cartridge it does not allow water to flow from the tank to the base.
Q: Unit is running intermittently.
A: How long has it been since the contents of the cartridge were replaced? If 2-3 months have passed, it is time to replace the contents of the cartridge. However the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit ceases operating at its full performance. If the contents of the cartridge were just replaced there are probably too many granules in the cartridge. Remove 2 tablespoons of granules from the cartridge.
Feb 20, 2010 | Air-O-Swiss U7142 Humidifier
Changing light after installing new water filter
Water Filter Status Indicator Light
(select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the LOCK and WATER
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Replacement water filter cartridge indicator light flashing
HOLD EITHER THE MENU OR OK BUTTON FOR BOUT 10 SECONDS, THIS RESETS IT!
May 29, 2009 | Whirlpool S20DRSS33 Side by Side...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
198 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
