Question about GE Profile DPSB620ECWW Electric Dryer
GE DPSB620EC1WW Will not turn on Heating Elements
I have a GE Profile Series Dryer that the heating elements will not turn on. New control board from GE did not fix the problem. 220 vac present at K2 & K3 on control board. Elements check out ok and centrifugal switches are ok and elements are ok, but control board will not turn on K2 or K3. Could I possibly have a bad Inlet or Outlet thermistor?
  • 1 more comment
  • Dan Tassell May 29, 2009
    As I stated in my posting, 220 vac present at K2 & K3 on Power Board. Elements are good and motor switches are good back to second leg of 220 vac. Something is telling Power Board not to turn on the elements. If I knew what the values of the Input/Output thermistors are suppose to be that would be a great help.
    Hi and thank you for the reply!
    Now we are getting somewhere. The Inlet thermistor (white wires) is reading 103K ohm and the Outlet thermistor (blue wires) is reading 7.3K ohm at room temperature. I am guessing the Inlet thermistor is so far out of range that the Power Board doesn't know what to do with it, so it does nothing. Sound like I am on the right track? Dan
  • Dan Tassell Jun 04, 2009
    Well, based on the information you provided, I went and purchased a new Intake thermistor. The new thermistor reads 96k ohms, not too far from the one I thought was bad, which reads 107k ohms. I thought the thermistor values you gave me were for both Input & Output. What gives? I now think I have a part I don't need. Do you have any other advice?
Were you able to solve this problem? I'm having exactly the same issue
Posted on Jul 10, 2010
  • 136 Answers
Yes... that is very possible... If they didn't fix your problem i'd complain if i were you... but there might be an issue with your motherboard... you should check to make sure the wiring and circuits aren't defective. i would suggest you reset your dryer... comment me if i didn't answer your question.. thanks
Posted on Jun 05, 2009
  • 10,515 Answers
GE DPSB620EC1WW Will not turn on Heating Elements - moz-screenshot.jpgmoz-screenshot-1.jpgNormal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Go to the Sears Website and type in your model number and from there you can get a pictorial view where this item is located.
Any further help, let me know.
Thanks for using "Fixya".
Do rate the solution as "Fixya" if 100% satisfied.
Posted on May 29, 2009
  • taran_2005
    taran_2005 May 29, 2009
    Yes, you are on the right track. The thermistor is bad.Once you fix this, probably it would fix the issue.
    Thanks for using 'Fixya".
    Sergeant:
  • 296 Answers
Hi
Things that could stop a electric dryer from heating:
You can check these things using an ohmmeter/multimeter from here.
http://www.applianceaid.com/test_with_ohmmeter.html
Things that could stop a gas dryer from heating:
hope you will b helpfull
regards
How to repair an electric oven that won't shut off?
call an electrician to test the switches for faults or the circuits for a problem
possible a loose active wire touching where it should not be from rotting insulation or loose screws
Sep 17, 2016 | GE Profile JDP47 Electric Kitchen Range
How do I know if it's the heating element or the blower motor
you need a service tech there if you arent the mechanical type
it could be the heating elements or a thermostat as welll
Aug 10, 2014 | GE Profile Harmony DPGT750EC Electric...
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
Ge double oven, no heating
check that u have continuity through the elements if you dont then replace the element next if you do have continuity through both elements check to make sure you have power coming from the main control to the element if you dont have any power leaving the control board then replace the control
May 18, 2010 | GE Profile JTP56 Electric Double Oven
Not heating. cycle still runs but there's no heat.
SOUNDS LIKE THE HEATING ELEMENTS HAVE BURNT OUT , REPLACE WITH NEW ELEMENTS .
Nov 01, 2009 | GE Profile Harmony DPGT750EC Electric...
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
The electric oven will not heat. Too the setting
If there is not heating at all, check the temp probe (SENSOR ASM (Oven Sensor Assembly)) the wirings to the elements, and the control assembly.There is also a thermal fuse that need to be checked.
If heating is poor, test both elements, check the vent system an control assembly.
You find diagrams and all parts for your appliance here.
Dec 21, 2008 | GE Profile JMP31 Electric Kitchen Range
GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 20, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
GE Profile DPSB620ECWW Electric Dryer Logo
299 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
