Question about Lexmark JetPrinter X1185 All-In-One InkJet
Ink wont work for Lexmark X1185
Help me please. When I print something it would print perfectly fine. But no ink would show on the paper
  • 1,601 Answers
Re: Ink wont work for Lexmark X1185
Is the cartridge in correctly? Is this a new printer or did it happene randomly one day?
Posted on Nov 09, 2007
0 characters
3 Points
I ddon't know how to get the printer to recognize the color ink that I have installed. The printer will not print.
Make sure you are inserting the correct cartridge for your model. Try to clean the print cartridge nozzles using the computer. Load plain paper. Open the Lexmark Solution Center (go to Start, Programs, Lexmark 1100 Series, Lexmark Solution Center). From the Maintenance tab, click Clean to fix horizontal streaks. Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles. Try to print your file again and check it's properly printing now.
May 04, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
When i try to print a test page it wont print it will start like it wants 2 print then it wont tho it coming up with an error like printing has been canceled and it saying that there may be something in...
my printer does not accept print command at 1 go , it keeps on giving the noise of printnig on & on but does not start printing. can u please give a solution to this
Nov 14, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
I have a Lexmark x1185 and it doesn't print anymore (It worked fine a few weeks ago). I can scan with it normally though. Basically, when I turn it on, the power button flashes... I already tried...
Hello. You might want to give it a fresh start by properly uninstalling it from your computer. To uninstall the software properly on Windows 7, go to Start Menu > Programs > Lexmark Series folder > Tools > Uninstall. Restart the pc. To reinstall, use this driver from the Lexmark website. Just click on the link: . Though it's a 64-bit Vista driver, it's the same driver used on Windows 7. Download and install the software.
Mar 11, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
Printer wont print, but it is going through the motions.
If ink cartridges are new, perform print head or maintenance cleaning at least 3x consecutively.
Nov 24, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark 1270
Could be your INK cartrage'is empty.or just cloged clean .it
hope that help you
Oct 28, 2008 | Printers & Copiers
Lexmark X1185 printer will not print color......everything else works fine
the ink is clogged not the cartridge but were the ink feeds into the printer. there should be a cleaner tab in the printer preference tab if available
Jan 08, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1180
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 13, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1180 blank ink not coming through
You can refill cartridges only a certain number of times.
Check the copper contacts and see if they look like new. any amount of wear and they wont work anymore. That being said, All printer manufacturers say to buy new and not refill.Maybe that is a moneymaker for them, however, I have never had good luck with refilled cartridges.
Oct 25, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
109 people viewed this question
Top Lexmark Printers & Copiers Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Printer and Copier Expert? Answer questions, earn points and help others
