Question about Fuji FinePix J10 Digital Camera
When i go back to look at my pictures on my camera some come up as read error
When i try to look at my pictures on my camera some come up as read error
I believe it is your memory card... I hade one do that to me... From what I gather, the card can get a bad spot on it and if taking a picture and you hit that spot it will not take that pic and just say read error... I would invest in another memory card....
Posted on May 28, 2009
Unable to read memory card after dropping camera
And you think that is the only problem?
The first thing I should try, is remove the memory card and read it on my computer. Use an external card reader.
If the card still holds pictures, reinsert the memory card and try again.
I don't know if the camera was on, while you dropped it. Because if on the right moment the camera was still writing to the memory it hit the floor, the complete file system can be corrupted.
If you can't read pictures on the external card reader, you should first try to recover all the pictures, because there is a reasonable chance, the pictures cam be recovered, even if the file system is corrupted.
Some errors on memory cards or pictures can be corrected with some recovery programmes, but not every error can be corrected. free software to recover your files on a memory card:
http://www.memorycard.freedatarecoverysoftware.org
www.cardrecovery.com www.wondershare.net with free trail
www.cardrescue.com with free evaluation version
If there are no important pictures, or no pictures at all on the card, you can skip the recover part. Just format the card with FAT 32. When placed back in the camera, do a format with the camera.
Success. I hope this is all damage on your camera, but ????
Jan 21, 2014 | Cameras
Read error appears after downloading pictures and looking back in the camera, some pictures have read error
When you hook your camera to your computer you are accessing it like a disk and changes made to "files" are saved to the disk. A common change is to rotate the image so it views correctly on the computer screen for images you turned the camera to take a portrait oriantation shot. That change is saved to the image on disk, then the camera can no longer display it because it is not the right "dimensions" for the camera (it is rotated)
Dec 13, 2011 | FUJIFILM FinePix S2950 / S2990 Digital...
I have a canon powershot sd 1200 is. I tried to transfer the photos from the camera into a laptop using the memory card; t didn't work. Put the card back into the camera. Now camera says...
This sounds like your card has some type of error that is causing the images not to be seen. My suggestion is that you go to your local chain pharmacy (such as Walgreens, CVS, Duane Reade) and put your memory card into their photo kiosk machine to read the pictures. Hopefully their machine will be able to read the memory card and then you can have them copy your pictures to a CD/DVD. After this is done then you would be able to reformat the card and clear the error. If the card still does not read or work then it seems you will need to look into a service that does data recovery.
Good Luck,
Paul
Jul 01, 2011 | Cameras
I gotmy new finepix camera in December. it works fine but sometimes when I am looking back at pictures I have taken it say read error and cant see the picture. what is the reason for this and can I fix it?
There can be two reasons for this problem.
  1. Might be your memory card is not working properly. Thats why reading or writing errors occurs most of the time. Try again by changing the memory card.
  2. Sometimes the data writing process of the camera could e malfunctioned, if so you have to give this to professional camera repair center.
Feb 28, 2011 | Cameras
Write error and read error appear after picture is taken.
pls update ur firmware from here it would likely resolve problem
http://www.fujifilm.com/products/digital/download/s1000fd/fupd.html
get back to me if it doesnt and do rate me FIXYA for help
Mar 29, 2009 | Fuji FinePix S1000FD Digital Camera
Read error
Try formatting the card in the camera using the setting in the camera's menu.
Some makes of xd or sd cards do not work correctly in fuji camera's. Sometimes even formatting them in the camera does not have any effect.
Mar 25, 2009 | Fuji FinePix F470 Digital Camera
Card read error on the digital picture frame - brand new. I bought this 7" digital photo frame from argos and I insert the SD card whilst the device is turned off, when I turn it on the message reads...
Put the card back into the camera and off load/take off your pictures (Put them on the computer). Then, put the card back into the camera and go to your options menu. Find the format feature, and format the card. Take some new pictures and then try putting the card back into the picture frame. Does it work? If so, transfer the images from your computer back to the card. If it continues to work, then Great! If not, more than likely there is an improper or corrupt file among your photos.
Good Luck!
Dec 12, 2008 | PANDIGITAL 7" Digital Photo Frame With...
Missing pictures
Hey flowernthe,
The error message “card cannot be read" means there was and error when the camera tried to access the memory card. To fix this you should make sure you are using the right kind of memory card, which for this kind of camera is a SD card, and it does not support SDHc cards. Since this camera uses SD cards I would make sure the slider on the side of the card is not set to the locked position. If this doesn't help I would make sure the memory card connecters are clean, and if they're not you can use a rubber eraser to clean them up. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 11, 2008 | Nikon Coolpix 4600 Digital Camera
READ ERROR
Go into your camera's setting menus, there should be an option to format card. Format the card and take a sample picture then try to see if it worked. If not you'll need try another card. Stop by a local camera shop the'll be able to test the card and camera to see if you need repair.
Aug 22, 2007 | Fuji FinePix S9000 Zoom Digital Camera
Fuji FinePix J10 Digital Camera Logo
222 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
