Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi 43FDX Rear Projection TV
Magic Focus comes up with error 5 - I know it is a convergence chip problem. Can it be fixed by getting the part.
  • 80 Answers
Yes, You will need to replace the 2 convergence IC's. Hitachi part # CZ01341. Generic part # STK394-160E These are the upgraded replacement parts. Also look for any burnt resistors near these IC's.
Posted on Jun 03, 2009
My hitachi 60"ultravision tv has a double image at the top in blue and yellow. the magic focus has no impact. any ideas?
Pretty common failure with rear projection CRT sets.
Sounds like one of your convergence amp chips have gone out.
You can buy the chips from several vendors, or kits.
Do a search with your model number and "convergence amp chips". Shop around for the chips as they seem to be getting cheaper as this type of TV isn't as popular as they once were.
I've picked up several used Sony and Mitsubishi sets for nearly free that had this problem..
Feb 16, 2015 | Hitachi 60SDX88B 60" Rear Projection...
What does it mean when you get a error code 5 when you are doing the magic focus?
Mean ur tv convergence board it is dead,any codes error at all,mean the tv convergence board have components it is dead and the board it just dosen't conververt it three CRTS tv colors Tubes like R,G,B colors lines yokes anymore.Now.The tv convergence board must have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.After the tv fixed it convergence board,the tv will run the entire Magic Focus function,without any error codes at all.The tvs shops will cost u like $300-350 for parts and labors.
Jul 10, 2011 | Hitachi 53UWX10B 53" Rear Projection...
The tv will not automatically come into focus
U have pictures out of focus?Like pictures colors seperates in lines?Ur tv convergence are dead.U know how solders?Must replaced 2 STK convergnece ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Magic focus error Hitachi 51F500A
ok, you have more than 1 post for this set--this model uses two of the STK-392-110 OR 392-150 Convergence chips.
If magic focus will not adjust the picture both chips need to be replaced--about 13 dollars in parts if purchased on Ebay.
Green is not offered to be adjusted since it determines the geometry of the picture--red and blue are adjusted to it.
Let me know how much skill you have and I can tell you how to fix the set--it requires two things--getting at the chips and being able to unsolder and replace them--there may or may not also be some resistors around them that are now bad and need to be replaced.
most shops get 300 or more for this repair--total parts cost if you are able to do it yourself is under 30 dollars.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 12, 2009 | Hitachi 51F500 51" Rear Projection...
Magic focus 4 error
Error 4 is listed as an overflow in the convergence section.
To fix:
1. Check the placement of the sensor
2. perform an Adjustment check of th H/V size & centering
3. Conv. amp. gain check, check these resistors:
R041, part # 0790024R, RES.CHIP 1/16W 100 OHM
R046, part # AQ00164R, RES.CHIP 1/16W 75 OHM TAPE
R050, part # 0790059R, RES.CHIP 1/16W 47K OHM
R058, part # 0790054R, RES.CHIP 1/16W 18K OHM
R062, part # 0790047R, RES.CHIP 1/16W 5.6K OHM
May 16, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Magic focus works briefly, then the tv is out of alignment
You need to replace the convergence chips and possibly some of the convergence resistors. You can buy the parts online from various sources or you can get a complete kit with instructions from www.TvRepairKits.com
Apr 19, 2009 | Hitachi 53UDX10B 53" Rear Projection...
How do i set convergance on my53uwx10B
you can go in through the back of the tv to set the focus you should be able to converge the tv from the remote.if not i would call a service tech and have them come and reset it for you.
Jan 21, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 29, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Magic focus, #5 Manual
Sounds like a Convergence IC problem, the convergence ics would need to be replaced. This can be done by yourself or a professional.
Jun 06, 2008 | Hitachi 57S500 57" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
306 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
