Question about Osicom 2300 Series 2340 Network Adapter
Want a manual for gme tx2300 radio
I would like a manual for a gme uhf tx2300 radio
Where can I get a Circuit Diagram for a Uniden UHF 012sx UHF CB Radio?
The only place you would get that is from Uniden themselves.
UHO12SX Manual - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH012.PDF
UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Features. 2. Preventative Maintenance. 2. Troubleshooting. 2. Controls/Connectors. 3. Missing: diagram ‎012sx
[PDF]UH8060NB - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH_8060NB_OM.pdf Operating the UHF CB Radio in Duplex Mode. 17. Scanning ... The Uniden UH8060NB is designed to provide you with years of trouble ... Built-in AVS Circuitry†.
[PDF]UHO12SX Manual.cdr - Uniden
https://www.uniden.com.au/RESOURCES.../uhO12SX_OM_2yrWarranty-Updated.pd... UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Controls/Connectors. 3. Indicators. 4. Included with your uh012sx. 5. Operation. UHF CB ...Missing: circuit ‎diagram ‎012sx
Circuit Diagram for Uniden UHF 012sx Google Search
Mar 19, 2017 | Uniden Radio Communications
GME 275A Circuit Diagram
http://www.eeserviceinfo for manuals circuit diagrams free
Jun 27, 2014 | Radio Communications
Gme TX3400 uhf radio only shows "TX34" when turned on. It will not operate. It was operating a week ago. What should I look for?
There are a lot of "ifs" in this, but...
If you are running the unit with a remote head, unplug both ends of the interconnecting cable and check both plugs and sockets for any signs of moisture. Also check for any obvious damage to the cable. If all appears OK, with the power off, clean the plugs and sockets with a contact cleaner spray, NOT a water-dispersant spray NOR a lubricant spray. Re-install the cable, reconnect the power and try turning the radio on. If still nothing, try activating/de-activating something such as the 'scan' function. If that changes things, there may be something that has been activated/de-activated accidentally - a few trial and error (successful) activations/de-activations of features will tell you if the main cable is working or not. If your unit is running with the head (control) unit attached to the body of the radio, detach the head carefully (instructions are in the user manual) and check the short interconnection cable as above. If still u/s, sorry, but the fault probably lies somewhat deeper in the unit. See if you can find a local service agent who deals with GME Electrophone products. If you are in Australia or NZ there are licenced agents in both countries. Elsewhere, check phone listings. Good luck.
Jun 14, 2014 | Radio Communications
Gme tx3800 cb radio not working
Martin-
Contact Get Support for more help.
Mark
Motorola Mobility Support
Feb 16, 2014 | Motorola Uhf 450-520 Mhz. Ht1000 Radio...
Uhf radio when turned on displayed LO does anyone know the problem
If it's a GME product it is most likly a low voltage supply to the radio
Apr 14, 2013 | Radio Communications
GME TX3340 not transmitting
You may have a bad microphone, not uncommon problem.
Apr 18, 2012 | Computers & Internet
Instruction manual for GME TX670 two way radio
You can get the manual on the link below. Please allow time for it to load.
http://www.gme.net.au/public/pdf/manuals/tx670_im.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 27, 2010 | GPS
Osicom 2300 Series 2340 Network Adapter Logo
Top Osicom Computers & Internet Experts
David Payne
David Payne
Are you an Osicom Computer and Internet Expert? Answer questions, earn points and help others
