Question about Motorola Computers & Internet
Modem password and login
I need my login and password from my modem to conncet my wireless router
  • 256 Answers
Modem login and password are required to set up your router. They are on your computer somewhere and I forget where. I've had a router for quite a while. The easiest way is th phone your internet supplier and ask them what they are. The package they sent you when you first signed up would contain all that but if it is lost (very comon) just check with your ISP.
Posted on May 28, 2009
I neet to conncet to the wifi
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Aug 03, 2011 | Computers & Internet
How to put password to wifi?
You cannot a put a password to the wireless card, but you can put a password for the wireless router/modem... You need to login into the router's interface and you need to configure the router by enabling the security.
May 23, 2011 | Encore ENLWI-N3 Wireless N 150 Desktop PCI...
I need connect a wirelees router a this modem,u help me plzzz
most wireless routers are setup for cable modems out of the box all you need to do is run an Ethernet cable from your modem to your wireless router. you can then access your wireless router by the ip address and a pc hooked you directly to the router.
Feb 28, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My neighbor is connecting to my router,Iwould like to stop him
For wireless security:
You need to login to your modem and add security, so that you can connect and your neighbour cannot. Unless you have changed your login details, look at the back or underneath your modem. It should tell you what your defualt login is and how to get to it. You normally access your modem using a web browser (Internet Explorer, Chrome, Firefox etc.) and typing in the address e.g. 192.158.0.1 in the top/address line.
Then you will be prompted for a username and password (see what the sticker on the modem says, e.g. admin and password.
Once inside that menu, look for WLAN or Wireless settings. You can then setup security e.g. WEP or WPA and some other options. Set the security to WPA and choose a password that you can remember. Once you have chosen Done/Apply/OK or similar, you will probably lose your connection. If you then choose your wireless, you will be prompted to enter a password.
The other alternative is, if you have a desktop connected by ethernet to the modem and don't need wireless, you can go into the same menu and switch wireless off.
Sep 29, 2010 | D-Link DIR-625 (790069292637) Wireless...
I have a netgear router and connot find my WEP #
ethernet from the router to the computer.....open browser...goto address bar type in 192.168.0.1
a pop down login appears login/user= admin
password= password. now you are in the config page of the netgear. look for wireless settings tab and click it. scroll down towards the bottom and you will see a code in key1 ( the bubble should be filled in green). that is your encryption code right there in key1. also the maybe something typed in the PassPhrase box, which i would also right that down. once you have written it down close out of the browser, and remove the ethernet cable. now its time to view available wireless conncetions. so try to use the key 1 code first, you should be good to go ....if the key 1 doesnt work try the passphrase.
Dec 31, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Need network security key or passphrase for my netgear DG834Gv4/DG834GBv4 !!! PLEASE( IP 192.168.0.1)
LOGIN
There is a login key for the router that can be accessed by opening the
address http://192.168.0.1 as described: after the login all settings inside the router can be changed.
Note: use a wired connection when going into the routers' ip address.
When you can not login with the default password, reset the device:
Restoring the Default Configuration and Password
This section explains how to restore the factory default configuration settings, changing the
router’s administration password to password and the IP address to 192.168.0.1. You can erase the
current configuration and restore factory defaults in two ways:
• Use the Erase function of the Web Configuration Manager.
• Press the WPS button and Wireless button on the side of the router simultaneously. You can
use this method for cases when the administration password or IP address is not known.
Resetting to Factory Default Settings
You can use this method for cases when the administration password or IP address is not known.
To restore the factory default configuration settings:
1. Press and hold the WPS button and the Wireless button on the side of the router until the Test
LED turns on (about 10 seconds).
2. Release the buttons and wait for the router to reboot.
WIRELESS SECURITY + PASSPHRASE
The wireless security is a network name for wireless connection called
SSID: the identification name of your router.
The passphrase is used for a secure password getting permission to have wireless data transfer from the router to the computer and vice versa. ( No internet connection so far: only Local Area Network [LAN] )
MODEM
Because the device is a router / ADSL modem you'r able to setup the
modem part for connection on a telephone line to the internet / Wide Area Network [WAN] .
You should use passwords from the Internet Service Provider [ ISP ] enter and save them in the modem section of the device.
Support for DG834G on the internet:
http://www.netgear.com/Products/RoutersandGateways/WirelessGRouters/DG834G.aspx
Sep 22, 2009 | NetGear DG834G Router
Default login & password
Default password for most of the modem is "admin"
If it doesn't help, then it will be mentioned in your modem user manual. For resetting your modem, you can use the hardware reset switch also. You can reset using that by inserting a small pin/needle into the hole located somewhere behind the modem.
Aug 03, 2009 | SMC Barricade g SMCWBR14T-G Wireless...
How can i setup a password for my modem
you need to login to your router and assign a password in the security field.
Jul 05, 2009 | D-Link DFM 562E (dfm-562e) Modem
Not able to Login to us robotics 9108 adsl modem
Try admin for the username with a blank password.
Chris
May 29, 2008 | D-Link AirPlus DI-614+ Wireless Router
Connecting a labtop to the modem
Can you provide the following details:
1. Are you attempting to connect via wired or wireless?
2. Is your laptop configured with a static or DHCP address?
3. If Wireless, are you using WEP or WAP, and do you have matching credentials betweent he router and laptop?
Dec 30, 2007 | Zoom 5515A (55150200A) Modem
Computers & Internet Logo
458 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
