Question about Troy Garden
My troy built rider will not turn over at all. Battery has been tested and plug has been changed. Nothing at all
  • 376 Answers
Check the inline fuse coming off the battery side of the solenoid. If that's good, check that there is power to the wire that plugs into the bottom of the solenoid when you turn the key to start (with the brake locked down). If there is, the solenoid needs to be replaced. That's probably as far as you'll have to go.
Posted on May 28, 2009
On our Troy built we can't start it unless we use jumper cables to touch battery terminal and then the starter
check switch for corrosion make sure all post male and the female plug are clean. Check power to switch with 12 volt test light if you have power to switch check your soilinoid there is one wire that activates your selenoid to send power to starer. .i would guess bad selenoid.
Apr 05, 2017 | Troy Garden
Why doesn't it start?
Might be a full tank of wet gas from over-winter condensation.
Apr 11, 2016 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy Built Bronco ridering tractor with a Kolher courage 18 597cc motor. When I go to srtart it turns over slow almost like a vapor lock, I have replaced the battery and has full charge. I h
The engine will have a valve lifter on the cam shaft to reduve the compression on start up if the valve clerances are too wide the lift will not work making it very slow to crank.
Sep 12, 2012 | Troy Garden
Fuse blows on lawn mower troy built bronco rider when seat switch is pluged in
bypass the seat switch with a paper clip and see if it blows out again if so follow the wires and see where its rubbing on metal
Jul 30, 2012 | Garden
Troy built 26j mini-rider troubleshooting
Engine starts, but will not move when clutch release.
Ran out of gas ..had this problem after refueling.
May 11, 2012 | Troy Garden
How to change the oil in my troy built pont where is the drain plug
Not sure what a pont is, or what motor you have, but on some of the Troy built small engines from Honda the geniuses designed the motor with no drain plug. You have to tilt or flip the engine over to drain oil out the filler
Feb 24, 2010 | Troy Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Have a riding Troy Built that just quit. Will not start. Tested battery, it's good. Has gas. Any suggestions?
Sounds like your electronic ignition has gone bad. Usually when they start going bad you can let the engine cool and it will restart. In your case, apparantly it gave no warning. Check it by unscrewing the spark plug, leave the lead wire hooked to it, placing the spark end of the plug against the head. Try to turn the engine over and see if there is any spark jumping from the end of the plug to the metal. If not, it's the electronic ignition. But be sure the plug you are using is good.
Jun 17, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
352 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
