Question about Goodmans CD car radio GCE358MPT CD Player
Goodmans CD Player blinking ''tel call''
Recently bought vehicle with stereo system already installed. Worked for a few days then problem occured. ''TEL CALL'' is continuously blinking on the display. The player has power I can change the Volume and EQ etc. but cannot play a CD or the Radio.
  • 11 Answers
SOURCE: CD player wont play disks, showing error 1 instead
The original user manual will define the headunits error readings. It is most likely an internal mechanical failure and will need to be repaired or replaced
Posted on May 21, 2009
  • 3 Answers
SOURCE: radio signal strength not very good
It is due to the vehicle antana. you need to purchase a antana booster. hook it to a 12v power plug antana from car to one side of booster and radio to other side. this will increase signal from car antana to radio and should fix problem. most boosters can be found at any car audio or truck stop and run from$10.00 - $25.00 good luck
Posted on May 22, 2009
SOURCE: JBL Marine MR-4
Hi I have a spa with the MR4 sterio and i want to remove it can you help as i am unable to remove it , the front comes of and i can not see how the rest comes out .
Posted on Apr 03, 2011
  • 30 Answers
SOURCE: My goodmans car radio /cd
Check the timer like on TV's where you can set a sleep timer.
Posted on Apr 10, 2011
kenw392
  • 2226 Answers
SOURCE: when key is turned
Make sure the yellow wire is going to a source that is still hot even with the key off. The yellow wire controls the memory of your deck.
Posted on Jul 11, 2011
Alpine car stereo manuals
Go to Alipne USA.com. They have them for display & download
Sep 01, 2014 | Alpine CDA-9835 CD Player
Kenwood kdc-x811 faceplate quit responding.
Call Kenwood they can give you a code to enter by using the remote
Mar 22, 2014 | Kenwood KDC-716S CD Player
Car Radio/CD player -Clarion R.D.S./EON- numbers on back PW546174 - I need a manual please
Hi
Go online to MANUALSONLINE.COM put the brand name in its place and the the code.
kolbbrun
May 14, 2012 | Goodmans CD car radio GCE358MPT CD Player
The unit worked fine for a long time. a few days ago i changed cds and when i put the cd in it sounds like it is spinning and then nothing and it ejects the cd..the radio still works on the unit. I just...
Some Panasonic stereo's don't like non shop bought, home burnt discs (they are recorded at a different level) so try new discs plus run a CD laser cleaner through your system.
Jul 12, 2011 | Panasonic CQ-C1101U CD Player
I just purchased a Nextar3.5"
The retail global position systems require components to perform considering the vehicle that rerquires installation. For example, retail brands of the GPS would have required to perform with the vehilce stereo device producing the audio dictations. At which point, a technical installatins expert deciphers the requirements by observing vehicles audio devices to allow for new installations. The gloabl position systme device provides the display screen where maps either as road guides torus or addreses are observable vsiabile to the operatoro of vehicle. Usually depending on the type fo system acquired would have audio telephone features that requir technical expertis eto install. Consulting with the auto electrical expert to observe the vehicle that already has stereos with modern featurres of telephony makes achievable manipulating another diaplay system to achieve operators experience. Once the global position device has been acquired from retail, cosnult with an auto expert that would ascertain about installation kits to harness onto vehicle. The request about installing the systems DVD or CD is acheiveble from an already establish stero device. Once intergated on the vehicle, inserting the DVD disk into stereo player displays result on the global systems screen from where has applications to produce searhc effect resquests.
Feb 14, 2011 | Nextar X3-03 Car GPS Receiver
How 2 remove d radio from 2000 corolla to install a cd player
you will ned some accessories to put it in properly.
1. 99-3413 metra install braket. will ease the mounting.
2. 70-1761 metra wire kit will allow you to fly through the hookup.
you will be able to get these parts at your local stereo install shop.
when you purchase the mounting kit the instructions on how to remove and reinstall your cd player will be in the instructions. illistrations and all.
Aug 28, 2009 | AviStart 5303 2-Way Security / Remote...
How to install a cd player without a wireing harness. Ok i bought an 1993 chevey s10 well some one cut off the part that goes into the factory tape deck.I already ran the wires for the speakers and i was...
If the speakers are working already, you will have to connect the red wire from the stereo to the yellow wire for the iginition. Black to black for ground, and yellow from the stereo to orange in the vehicle wiring. If you are using a test light, the orange should be constant +12 volts, yellow will have switched +12 volts. This will turn off the stereo with the key.
Please be sure to give a rating. thank you.
Jun 12, 2009 | Pioneer DEH-P3600 CD Player
Radio signal strength not very good
May 21, 2009 | Goodmans CD car radio GCE358MPT CD Player
Goodmans gpdr40
Ive put The Install CD On a temp web site they are in a zip form so make sure you have some software to unzip them ... Like winZip.
http://playerzipfile.googlepages.com/
Apr 18, 2008 | Goodmans GPDR40 Digital Media Player
I think it got wet
Yike! As with most electronics, they are necessarily dead when they get wet, but you do have to be very careful with them until they're dry. Here's the best you can do:
  1. Remove the stereo from the boat completely.
  2. Remove the cover(s) from the stereo to expose as much of the inside to air as possible.
  3. Let it sit for a few days inside to dry.
  4. Reassembly it and install it back in the boat.
If you're lucky, the unit will return to normal operation. Unfortunately, my guess is, since you powered the unit up when it was wet, damage may have already been done.
Mar 13, 2008 | Jensen CD400M CD Player
Goodmans CD car radio GCE358MPT CD Player Logo
223 people viewed this question
Top Goodmans Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
rpar
Are you a Goodmans Car Audio and Video Expert? Answer questions, earn points and help others
